Re: Master Cylinder Push Rod Retainer.
[Re: 70dart318]
#1344983
12/03/12 12:04 PM
12/03/12 12:04 PM
RapidRobert
I've used a snip of vacuum hose the same length as the recess at the end of the pushrod (I forget the dia needed). I've had the correct ones & the above side by side & no difference ex for a groove along the length of the correct ones. I just assumed that it is to let air out as you push it into the piston blind hole so it will seat in there correctly. I cut a groove & the snip of hose locks in super tight/never an issue
