Page 1 of 3 1 2 3
Crack block dang gone it ! #1344675
12/01/12 09:14 PM
12/01/12 09:14 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Well I was going to use this Block. it had real good sonic check numbers..put it on the stand and was check it out. this is what I found !
Re: Crack block dang gone it ! [Re: VernMotor] #1344676
12/01/12 09:19 PM
12/01/12 09:19 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Look at it this way. Better to find it now, before you sank hundreds of dollars of machining work into it, only to find the crack afterwards.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Crack block dang gone it ! [Re: DusterDave] #1344677
12/01/12 09:20 PM
12/01/12 09:20 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Wow - good eye!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Crack block dang gone it ! [Re: 69dart] #1344678
12/01/12 09:49 PM
12/01/12 09:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I wouldn't discount that one just yet, that can be repaired.
Re: Crack block dang gone it ! [Re: dartman366] #1344679
12/01/12 09:52 PM
12/01/12 09:52 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Water glass?
Re: Crack block dang gone it ! [Re: DusterDave] #1344680
12/01/12 10:08 PM
12/01/12 10:08 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
double check the area around the main cap webbing also
another weak spot for stock blocks
Re: Crack block dang gone it ! [Re: nss guy] #1344681
12/01/12 10:11 PM
12/01/12 10:11 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Bill that is the one we was looking at the numbers we liked
Jim it is a std bore stock motor never been in a race car. But I look at it..
Re: Crack block dang gone it ! [Re: VernMotor] #1344682
12/01/12 11:09 PM
12/01/12 11:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I think the other one is equally as good.
Re: Crack block dang gone it ! [Re: dartman366] #1344683
12/01/12 11:15 PM
12/01/12 11:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'll take it off your hands.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Crack block dang gone it ! [Re: VernMotor] #1344684
12/01/12 11:18 PM
12/01/12 11:18 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
why not buy a new block? why start with a 40+ old foundation.
Re: Crack block dang gone it ! [Re: rickraw] #1344685
12/02/12 12:03 AM
12/02/12 12:03 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
If I had your money I would do that ! LOL
Re: Crack block dang gone it ! [Re: pittsburghracer] #1344686
12/02/12 12:05 AM
12/02/12 12:05 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
John I got 70 bucks in it. come pay me and take it away.
Re: Crack block dang gone it ! [Re: VernMotor] #1344687
12/02/12 12:05 AM
12/02/12 12:05 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
weld it up. its outside
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Crack block dang gone it ! [Re: bigtimeauto] #1344688
12/02/12 12:16 AM
12/02/12 12:16 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
weld repair and run it, specially since it checked out on the cylinders
Re: Crack block dang gone it ! [Re: bigtimeauto] #1344689
12/02/12 12:17 AM
12/02/12 12:17 AM
PA.
"Little"John
"Little"John
PA.
That's so easy to fix it isn't funny.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Crack block dang gone it ! [Re: VernMotor] #1344690
12/02/12 12:20 AM
12/02/12 12:20 AM
I would put the freeze plugs into it and then pressure check it I've seen casting flaws that looked like that, no leaks. I have also seen casting flaws that did leak Most cracks don't go in circles
Re: Crack block dang gone it ! [Re: pittsburghracer] #1344691
12/02/12 12:22 AM
12/02/12 12:22 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well I am not sure I know anyone who I would trust to weld cast. and who is to say that it is not crack more inside ? maybe I will take it back up and have it magaflux . make sure there is no other cracks.
Re: Crack block dang gone it ! [Re: pittsburghracer] #1344692
12/02/12 12:23 AM
12/02/12 12:23 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Investigate further
Re: Crack block dang gone it ! [Re: Hot 340] #1344693
12/02/12 12:41 AM
12/02/12 12:41 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have welded a few blocks on the outside, even new ones. we put them in the mill to lighten them up and sometimes you go thru! just weld them up and keep going.
Re: Crack block dang gone it ! [Re: VernMotor] #1344694
12/02/12 12:51 AM
12/02/12 12:51 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That looks like a frozen block crack. If thats the only crack it can be welded rather easy. But, Id be looking for other cracks as well. another weak spot is in the intake vally. Check closely in there as well. If the block was full of water and freezes it cracks pretty easy in there.
The crack or damage you show now could of been just residual water that didnt drain out of that area and may be the blocks only damage. If so, like others have said , easy fix. I can weld it for you.
Question for you. You stated on another post that you were testing several blocks, like 7 or so, I think. Were any of those blocks .040 over? If so Id be interested in one.
Page 1 of 3 1 2 3
