Broken Axle Bearings? #1344625
12/01/12 07:16 PM
12/01/12 07:16 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
I'm swapping the 3rd member in mt roadster from 4.77 gears to 4.30 gears this winter but had a nasty surprise when I pulled the axles. The press on bearings are physically broken on both sides? Has anyone seen this before? What could cause something like this?
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Broken Axle Bearings? [Re: 69dart] #1344626
12/01/12 08:33 PM
12/01/12 08:33 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
i have never seen that bearing with that cover plate together
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Broken Axle Bearings? [Re: 69dart] #1344627
12/01/12 08:38 PM
12/01/12 08:38 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Have you had this apart before and know that they were not installed like that? It looks to me like they were damaged when they were installed on the axle.
Re: Broken Axle Bearings? [Re: 446acuda] #1344628
12/01/12 09:05 PM
12/01/12 09:05 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
That is what I said...
Re: Broken Axle Bearings? [Re: VernMotor] #1344629
12/01/12 09:23 PM
12/01/12 09:23 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
The one side always had a bit of fluid on it but this was the first time I have pulled the axles since buying the car a couple years ago.
68 Dart - 340
66 Belvedere - 400
Re: Broken Axle Bearings? [Re: 69dart] #1344630
12/01/12 09:44 PM
12/01/12 09:44 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I'd take a real close look at the straightness of the housing and alignment of the ends. It looks like the rollers were trying to roll out of their grooves.
Re: Broken Axle Bearings? [Re: 69dart] #1344631
12/01/12 09:44 PM
12/01/12 09:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would say someone did a poor install on those bearings.
Re: Broken Axle Bearings? [Re: 69dart] #1344632
12/01/12 10:10 PM
12/01/12 10:10 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Thanks Guys other than an install or alignment issue the only thing I can think of is that I did have the car up on its side on 2 wheels one day when I got way loose and took out the 1.8th mile timing blocks. I would think those bearings could take that abuse though. Apparently it has 4.56 Pro Gears in there part # 80-0570-1 rather the 4.77's. So now I'm thinking a 4.11 might be better as the engine builder thinks it will run low nines with the new engine. I plan to double enter and run as much as I can next year so I'd like to keep the RPM's down on the big end.
68 Dart - 340
66 Belvedere - 400
Re: Broken Axle Bearings? [Re: 69dart] #1344633
12/01/12 11:24 PM
12/01/12 11:24 PM
I take it that the rear end is Ford nine inch style, yes or no If so check the housing for straigthnes by reinstalling the axles and measure off of the axle flanges out around 16 inches from center to the front, back and up and down, I use two steel carpenter squares, check the edges for straightness agianst each other I'm shocked that niether one of the outer races broke into two pieces DUDE, you dodge a big bullet
Re: Broken Axle Bearings? [Re: Cab_Burge] #1344634
12/02/12 11:06 AM
12/02/12 11:06 AM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
Yes the rear end is from a Ford 9"
68 Dart - 340
66 Belvedere - 400
Re: Broken Axle Bearings? [Re: 69dart] #1344635
12/02/12 11:50 AM
12/02/12 11:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you pulled the third member... I only seen that
once and a chunk of gear got in there... thats what
we ASSUMED because there was a chunk of gear right
near it
Re: Broken Axle Bearings? [Re: MR_P_BODY] #1344636
12/02/12 11:55 AM
12/02/12 11:55 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Were the broken pieces from the bearings inside?
Re: Broken Axle Bearings? [Re: MPerry] #1344637
12/02/12 12:29 PM
12/02/12 12:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your asking me this question... yes.. chunks were
in the bottom.... and I am SURE the chunks are in his
Re: Broken Axle Bearings? [Re: 69dart] #1344638
12/02/12 01:36 PM
12/02/12 01:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Make sure the ends of the axles are not pre-loading against them selves or on the inside of the carrier.
Re: Broken Axle Bearings? [Re: MR_P_BODY] #1344639
12/02/12 01:54 PM
12/02/12 01:54 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Actually I meant him because I don't see the missing pieces in his pictures.
I would assume a bad bearing installer might have left the broken pieces out.
Re: Broken Axle Bearings? [Re: MPerry] #1344640
12/02/12 09:57 PM
12/02/12 09:57 PM
Johnstown
69dart Offline OP
69dart  Offline OP
Johnstown
The 3rd member looks perfect. The bearings were in one piece until I pulled them out of the housing then the chunks fell off. The housing was clean of shrapnel as well.
68 Dart - 340
66 Belvedere - 400
Re: Broken Axle Bearings? [Re: 69dart] #1344641
12/02/12 10:06 PM
12/02/12 10:06 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
either as previously stated, the bearings could have been damaged when they were pressed on. if u had the car on 2 wheels as u mentioned, it could have put excess pressure on the bearings.
