torque thrust restoration
#1344608
12/01/12 06:36 PM
12/01/12 06:36 PM
Posts: 2,270 St.Louis, MO
694406
St.Louis, MO
Does anyone have tips on restoring vintage torque thrust wheels? Thanks.
www.Musclemagnet.com1969 Cuda 383 Q5 1969 Cuda 340 4-spd Notch 1969 Cuda 383 4-spd Notch 1969 GTS Black on White 340 4-spd 1971 Cuda 383 V2, X9 Billboards, White Top!
Re: torque thrust restoration
[Re: 694406]
#1344609
12/02/12 12:51 PM
12/02/12 12:51 PM
Posts: 9,835 MI, usa
dvw
MI, usa
They have machining marks in them even when polished. I remove them. Start sanding with the finest grit you need to remove flaws. This may be 80 grit. If only a few flaws don't 80 grit the entire wheel. If you have something to spin them with it will be faster, I've done them by hand as well, just takes longer. Make sure to remove all previous grit scratches every time you go to a finer grit. Sand at aprox 30 degree angle after changing grits to ensure you remove all the previous scratches. The rear of the wheel can remain 80 grit for the brushed look. sand 80,150,240,400,600,1000. Then polish. Then tape the polished surface off and sandblast the center. I always paint the spokes as it makes them easier to keep clean, Grey,black, silver, what ever you want them to look like. Tapeing them off to paint is the longest part of the whole process. If you can spin them ( brake lathe works well) sanding takes about 1 hour on the worst wheels. Polish about 1/2 hour. Here's the last ones I did (though they are 200 S). The rears came from 1968. I used a lot of 80 grit. Doug
[Re: dvw]
#1344611
12/02/12 01:22 PM
12/02/12 01:22 PM
694406
St.Louis, MO
Awesome, thanks for the tips!
[Re: 694406]
#1344612
12/02/12 01:31 PM
12/02/12 01:31 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
If the as-cast spokes need cleaned up, mask the lip with heavy tape (like duct tape) and bead blast them.
Then figure out a way to spin them. I mounted the set of 200-S I did on my wife's Explorer. Put the rear on jack stands, mounted the wheel and then ran it in manual low/first gear.
Mine were really crusty. I started with relatively coarse crocus cloth and worked my way through progressively finer sand papers. I wanted a satin polished look (versus the stock machined lip) so I finished with coarse steel wool before final polishing.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
