Page 3 of 6 1 2 3 4 5 6
Re: Green Bearings [Re: doctor_mopar] #134442
10/14/08 09:26 AM
10/14/08 09:26 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have been using Green Bearings since they first came out.Both street and strip.The only problem I have ever encountered is one had the seal fail and leaked.That's one in about a thousand.
Re: Green Bearings [Re: fbernard] #134443
10/14/08 10:02 AM
10/14/08 10:02 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Fabien,
I'm guessing your friend has the Wilwood kit with parking brake shoes in the rotor hat. Did you install the snap ring directly against the housing end? Unfortunately, Wilwood's instructions don't mention you must use the 5 hole retainer that comes with the bearings as a shim to properly space the axles away from the differential internals. Otherwise, constant preloading will destroy the wheel bearings.
Re: Green Bearings [Re: fbernard] #134444
10/14/08 10:50 AM
10/14/08 10:50 AM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
I second the motion. I replaced to greens at least a decade ago. So far I have years of autocrossing, two track days as well as tens of thousands of miles of spirited driving - no failure yet.
A friend's car I installed a Wilwood disc brake kit on (which required snap-ring green bearings) is currently on its 4th set of bearings in under 2 years. The previous set (the 3rd) survived road use and drag racing easily. But rally and spirited driving killed it in ONE DAY.
My car did the same with tapered bearings (no rear discs), and they're still fine. They're at least 15 years old.
First a question and then a comment with more questions Are Green bearings a "brand of bearing or a style that uses a typical sealed ball type bearing? Does Green manufature their own bearings or do they buy them from vendor and assemble the kits? I tried googling Green bearings and only came up with forums like this one or old history (1930s) about the original Green company. Who makes these bearings??? ok several questions...
I ask these questions because I'm really torn here. I have seen testimony both ways. As people are using these ball bearing under condition that are considered by many to be adverse to their design, I have to wonder if there aren't other factors at play. What is making some Greens fail where others last "forever" under what guys are decribing as mild to severe abuse and or "spirited driving", and what would make a tapered bearing fail under conditions that they were made for? Poor fit up?, Is the supplier of the Greens the same each time? Maybe they have a defective batch. I'm hoping to change these bearings once. The stock ones lasted 102,000 in 34 years and failed only because they went swimming for three days and then sat to dry in time I'm a 53 year old kid I plan to do some spirited driving myself but I don't want the first thing my grandaughter has to do to is is changer axle bearings. Like I said, I'm still torn.
Re: Green Bearings [Re: Scott Carl] #134445
10/14/08 10:59 AM
10/14/08 10:59 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
It isn't aero space mechanical engineering to properly install the tapered bearing but too many let the process intimidate them. In all the years around them OEM there were very few failures of the tapered bearings and in the many 8 3/4 rears in the JY the vast majority (as I have said before) are virgin with many miles left in them. Many do it your selfers also do not realize that the bearings must be packed with a good wheel bearing compatable grease before assembly or they will fail. They do not realize and nobody told them that the bearings are not lubricated from the rear end lubricant. So consequently the bearings are put in dry, a sure fire cause of premature destruction. Failure rate is usually not bearing related but installation related. There are times when using green bearings is a must as when using a spool.
Re: Green Bearings [Re: DoctorDiff] #134446
10/14/08 02:59 PM
10/14/08 02:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My orignal post was a response to this quote:
"A tapered Timken bearing is a beautiful engineering masterpiece."
I don't agree an adjustable Set 7 bearing is an "engineering masterpiece". I think it is a mediocre design, which is needlessly complicated and it causes several problems which I listed.
The same logic can be used to urge others to scrap their Hemis in favor of the much simpler flathead six. Cheaper, more reliable, ad nauseum.
A ball bearing that has to be manufactured to fit an existing OD and ID will be limited to the size/number of balls that can be installed without a loading slot. This makes for a "mediocre design".
Re: Green Bearings [Re: DoctorDiff] #134447
10/14/08 03:11 PM
10/14/08 03:11 PM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
Fabien,
Yep, that's the one. Wilwood kit 140-7144 .
Ooops! you're right, we never used this retainer (thanks Wilwood). We'll try and see what happens.
Thanks Cass!
Edit :
when we installed the kit, the axles did not touch each other. Where would the preloading come from? is the housing not deep enough for the bearing?
Re: Green Bearings [Re: John_Kunkel] #134448
10/14/08 03:17 PM
10/14/08 03:17 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Are Set 7 adjustable bearings an engineering masterpiece? No. Are Set 7 bearings suited for all applicatoins? No.
Are Green bearings an engineering masterpiece? No. Are Green bearings suited for all applications? No. I would love to see a tapered version of the MO-400 design Green wheel bearing.
Once again, here is what I originally posted in this thread: "Although most people won't have problems with the snap-ring style Green bearing (not the crimped on flange, RP-400 design still sold by Mopar Performance), the non-adjustable, 3.15" bore Timken set 20 tapered bearing is the strongest, commonly available wheel bearing. Unfortunatley, special housing ends are required to run this bearing on a Mopar application."
Re: Green Bearings [Re: Scott Carl] #134449
10/14/08 03:20 PM
10/14/08 03:20 PM
Omaha, Nebraska
Omaha, Nebraska
[quote
Still curious about this. Is it a secret?
Re: Green Bearings [Re: DoctorDiff] #134450
10/14/08 03:27 PM
10/14/08 03:27 PM
Kirkland, Washington
Pacnorthcuda Offline
From Mopar Action:
Found by a yahoo search of 'Mopar green axle bearings'.
right or wrong
"Ray, the Greens are low-capacity ball bearings...maybe 1/10 the side-load capacity of the stock Timkens. They are fine for drag racing, pretty lousy on the street, and pretty scary if you're into cornering or towing! (Admittedly, I've never personally seen one catastrophically fail, but I've seen plenty get noisy and sloppy).
The Fords are sealed rollers, way better than balls. The reason why you don't see more of 'em is 'cause they require you to weld on custom axle housing "ends". I have featured these earlier in the mag, as a way to dump the C-clips on 8.25 and 9.25" axles.
I also must add that, except that they require more care during assembly (packing with lube, endplay adjustment, etc.) the stock Timken tapered roller setup is about as good as it gets.
Rick"
OBVIOUSLY many people disagree
Re: Green Bearings [Re: Pacnorthcuda] #134451
10/14/08 04:54 PM
10/14/08 04:54 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
From Mopar Action:
right or wrong
"The Fords are sealed rollers, way better than balls. Rick"
WRONG! Fords are sealed ball bearings. Here is an OE Ford 3.15" sealed bearing with the shield removed. Obviously a ball bearing.
Re: Green Bearings [Re: DoctorDiff] #134452
10/14/08 08:39 PM
10/14/08 08:39 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Just had a shop manager bring an axle by to match up for a replacement I had. A local machine shop had pressed the tapered bearing on backwards, and the shop had intalled it that way !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Green Bearings [Re: doctor_mopar] #134453
10/14/08 08:51 PM
10/14/08 08:51 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Will the mean-greenie ever die ? ... NO way.
But I have been doing this stuff for longer than most here have been alive. And I have never seen a bad set of Timkens .... ever !!! And I have seen some that probably should have been changed ... but I cleaned-em-up and GREASED-em-up(well) and went on my way. The greenies ? ... if you eyeball them the wrong-way -- they .
Now I am not saying the Timkens do not fail .... but in no way in the same #'s as the balls.
Re: Green Bearings [Re: doctor_mopar] #134454
10/14/08 09:03 PM
10/14/08 09:03 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I think many people do that! They install it like a
front wheel bearing.
Re: Green Bearings [Re: 446acuda] #134455
10/14/08 09:05 PM
10/14/08 09:05 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
From Mopar Action:
right or wrong
At least that one has a steel ball carrier, the greens I had used a plastic carrier.....
Re: Green Bearings [Re: Dart 340] #134456
10/14/08 09:14 PM
10/14/08 09:14 PM
Upper Midwest
Upper Midwest
Like I said above the biggest failure rate is due to installation error, not bearing quality. It doesn't take any thought to install green bearings.
Re: Green Bearings [Re: fbernard] #134457
10/14/08 10:02 PM
10/14/08 10:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Fabien,
If the snap ring seats against the housing end, each axle will insert 1/8" deeper than they are intended. The thrust block inside the carrier will preload and destroy the wheel bearings.
Re: Green Bearings [Re: Scott Carl] #134458
10/14/08 10:05 PM
10/14/08 10:05 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Green Bearing Company was the original manufacturer. Bearing Technologies bought out Green Bearing Company a few years ago.
As far as I know, Green bearings are not available from any auto parts store.
Re: Green Bearings [Re: DoctorDiff] #134459
10/14/08 11:15 PM
10/14/08 11:15 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Man Doctor Diff!!!! You do type ALOT!!!!! Anyway, my 3.91 center came, along with the offset hangers and GREEN BEARINGS that I ordered from you last week. I'm SURE I won't be calling for any installation questions!! I may call for axles if I break my stock ones at the track though!! Thanks again for the great service!!!
Chris from New Jersey
Re: Green Bearings [Re: DoctorDiff] #134460
10/15/08 01:12 PM
10/15/08 01:12 PM
fbernard Offline
fbernard  Offline
Fabien,
Cass,
I agree it could have been the case with the previous center section (we did install the brakes before changing the diff).
But with the new one we bought from you (3.55 gears/489 housing/1350 yoke/Truetrac diff), we left out the thrust block. Axles should be spaced apart.
Re: Green Bearings [Re: fig426] #134461
10/17/08 12:57 PM
10/17/08 12:57 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
This topic is a good example of one of my favorite phrases: 'Just because someone knows how to work on things doesn't mean they know how things work.' There are good points (and bad points) brought up by both sides here.
About a year ago I found a copy of this article, today I was able to find it on the web. I encourage everyone with an interest in this topic to read this article and learn a little about bearings. It clearly explains the advantage the tapered bearing has over a roller bearing in a wheel bearing application.
The factory application/designs have a Factor Of Safety associated with them, and it's evidently high enough that a lower-capacity roller bearing can be installed in its place without a tremendous amount of failures.
The roller bearing is clearly inferior to the tapered roller from a load-bearing perspective, however there are other factors in a rear axle application that are the reason this topic brings passionate feelings from both sides. We should focus on simple things like engine oil or filters instead.
As for me, I'll stick with my Timken rollers, clean/re-grease them periodically, and worry about my other worries instead...
http://www.schaeffler.com/remotemedien/m...here_roller.pdf
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
