slant six low compression how low is low?
#1344371
11/30/12 11:50 PM
11/30/12 11:50 PM
Posts: 597 Lost in the 70's
440gtx6
Lost in the 70's
Picked up an old Hobart G300 welder with a Chrysler engine. It's a 170 cu. in. slant six and I'm only getting 40 psi on each cylinder when I check the compression. I know it's only supposed to be an 8.5 to 1 comp ratio but doesn't 40 seem way low for even a 8.5/1 motor? I don't have any experience with these sixes so guess I could use some advice. Thanks
69 EF8 GTX 440 auto 72 EB5 RR/GTX 440 auto 70 EW1 GTX 440-6 4 spd 70 EF8 Satellite 318 auto (452 coming soon) 70 FK5 Satellite 318 auto 71 FC7 Cuda 340 4 spd
Re: slant six low compression how low is low?
[Re: 440gtx6]
#1344372
12/01/12 12:24 AM
12/01/12 12:24 AM
RapidRobert
it's almost deceased. Only a /6 could still run with it that low. You might adj the valves, .010" intake/.020" ex and I like to loosen the plugs several turns then tighten them up & reinstall the plug wires & start it & rev it to blow the loosened carbon chips out which can lodge under a valve & give a false low reading (but not low like you have) & only takes an extra minute or 2 when doing a compression test.
[Re: RapidRobert]
#1344373
12/01/12 12:38 AM
12/01/12 12:38 AM
440gtx6
Lost in the 70's
Lol, yea that's what I figured. I have no idea how long it's been since the thing ran, bought it at auction a few years back and just now getting around to messing with it. Hopefully they just parked her because the engine was weak rather than a problem with the welder head. I would probably spend a few bucks and overhaul the six but probably tough finding parts for the generator side and $$$ too.
[Re: 440gtx6]
#1344374
12/01/12 12:42 AM
12/01/12 12:42 AM
RapidRobert
You might pick up a /6 for cheap and or see if the welder head is OK first
[Re: 71yelladustr]
#1344378
12/01/12 05:30 PM
12/01/12 05:30 PM
Posts: 20,173 Park Forest, IL
slantzilla
Park Forest, IL
Pour some turpentine down the plug holes and let it sit overnight. As said before, check the valve adjustment too.
One thing you will have to watch swapping a 225 in will be clearance for the top of the motor, and exhaust routing. The 225 is taller than a 170 by a couple inches. Also, the crank flywheel register diameter changed in 1968 so your coupler may not fit.
[Re: slantzilla]
#1344379
12/01/12 05:33 PM
12/01/12 05:33 PM
slantzilla
Park Forest, IL
FYI, 8.5 is probably optomistic. True cr is usually closer to 7.5:1.
