Re: Need advice: Flat tappet or roller in my hemi?
[Re: Thumperdart]
#1343602
12/01/12 02:28 PM
12/01/12 02:28 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Good info from all you guys that actually run, or ran, each of them. On the roller side, are the $500 rollers sufficient, or do I need to be stepping up to the $1000 ones?
I`m running the Isky solid body lifters and I don`t remember exactly how much they were but WAY under a grand and they rebuilt em for $200.00 iirc.
You have not looked in awhile
[Re: fig426]
#1343606
12/02/12 04:40 PM
12/02/12 04:40 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
No question, I'd go solid roller. Buy good stuff and there's no need to worry. I'm freshening up my hemi now after 6 years of street/strip abuse. Sent the lifters back to Isky (Red Zones) for a checkup and got a call back saying they needed nothing. Putting in a new bronze dist. gear shaft too. I check the lash twice a year. I say check b/c they never need adjusting. My cam is fairly mild, springs are 220# on the seat, 600# open. Motor makes over 800 hp on pump gas.
[Re: fig426]
#1343608
12/02/12 09:29 PM
12/02/12 09:29 PM
Posts: 370 Real North Cal.
66er
Real North Cal.
I have Isky Endurance Plus lifters. I paid about $400.00 seven year ago, they are now $800.00+. I wish I would have bought the Red Zone lifters, they were $700.00 back then. Now Red Zone lifters are less than $1000.00. You are buying year/miles/passes. I you think about it that way the more expensive lifters may be much cheaper in the end. I paid $400 and had them rebuilt once for $200. I could have almost bought the Red Zones and gone much longer without rebuild. The best thing about the high end lifter is the bearing are pressure fed with oil (like the crank and connecting rods), not just splash. You may be able to buy cheaper stuff and it may live a long life, but the high end part give you the insurance.
[Re: 66er]
#1343609
12/02/12 09:50 PM
12/02/12 09:50 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Isky will never get another dime from me and I'll leave it at that. I have a set of comp 848's that have pushrod & needle/axel oiling.Had them rebuilt at about 10k miles,they looked great when they came out but I had then rebuilt anyway just as PM. A friend of mine just bought Crowers,they look real nice as well.
[Re: 383man]
#1343611
12/05/12 12:05 PM
12/05/12 12:05 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
As usual everybody is going to tell you to put a roller cam in it. Keep it simple and leave a flat tappet in it. Flat tappets have low springs pressures. Everything is happy. Have the cam nitrided.
2011 Drag Pak Challenger
