Need advice: Flat tappet or roller in my hemi? #1343580
11/30/12 06:17 PM
11/30/12 06:17 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I've been researching, researching, and researching. It seems that with the solid flat tappet, I was always concerned about losing a lobe due to the current oils, even though I put in plenty of additives. So since I have my engine apart, I've been thinking solid roller. But from what I read about that, is, I'll be trading my concern for losing a lobe with a concern for losing a roller. So where do I go with this? I had no problems with my solid flat tappets with about 50 runs on it, although it was only .630 lift, shifting at 6300, through the traps at around 6800, if my tach is accurate. 10.96 @ 124mph.
It's the 528" hemi that I dropped the valve in over the summer. I've gone up to 11.3:1 compression, will be going aluminum heads. 3800 stall footbrake 727. 430 gears. 29.5 tire. 4000lbs. 2 750's on an open plenum intake. 2 1/8 supercomps through 3.5" aero chambers.
Chris from New Jersey
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343581
11/30/12 06:23 PM
11/30/12 06:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think if I was going to spend the money on a Hemi, I'd go roller....
Coming soon!!!!
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343582
11/30/12 06:27 PM
11/30/12 06:27 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
There's no question. A roller cam, even all other things being equal, will have less rotating friction.
If the camshaft profile is correct, you can get a bit more power and drivability out of the same lift and duration because of the increased ramp. And, like you say, it removes the oil additives problem, and also removes the need for breaking in a cam which is always a dice roll.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343583
11/30/12 06:30 PM
11/30/12 06:30 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
If you can afford to do it with good quality part ie: Isky tool room or manly next tech spings, Isky Red Zone or Crower Sever duty lifters, then the solid roller is the way to go. They make great parts that will last a long time.
Re: Need advice: Flat tappet or roller in my hemi? [Re: VincentVega] #1343584
11/30/12 06:32 PM
11/30/12 06:32 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
One other thing. I'm not chasing ET's here. I'm happy being an 11.0 car. Although hitting 10.96 for the 1st time was pretty cool.
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343585
11/30/12 06:47 PM
11/30/12 06:47 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Don't forget the bronze gear. Has Comp Cams come out with the Int. shaft gear that will live?
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343586
11/30/12 06:55 PM
11/30/12 06:55 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u could have trouble with rollers too. loose one & u have big time damage. next time i need a cam, i'm changing to a flat tappet. run some bradpenn, break the cam in without the inner spring & u'll be fine.
Re: Need advice: Flat tappet or roller in my hemi? [Re: 66er] #1343587
11/30/12 07:44 PM
11/30/12 07:44 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
.....and don't go crazy with the lobe profile.
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343588
11/30/12 09:01 PM
11/30/12 09:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Adjust the lash frequently. If one valve starts to move, pull and inspect that roller.
As little idle as possible.
Don't second-guess the mfg. on spring loads.
Boffin Emeritus
Re: Need advice: Flat tappet or roller in my hemi? [Re: polyspheric] #1343589
11/30/12 09:37 PM
11/30/12 09:37 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there are improvements you can make to flat tappet systems these days such as nitriding, face fed oiling on lifters and tool steel lifters. i know roller systems are superior but solid cams have made a lot of power over the years. i've never had any problems (having said that i now will) and for sure having a failure is a real mess but i believe if sound practices are used a solid can live a long happy life
Re: Need advice: Flat tappet or roller in my hemi? [Re: jamesc] #1343590
11/30/12 10:02 PM
11/30/12 10:02 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I wouldn't spend all the money required to switch to a roller unless I was looking for every last bit of power.
As you have found out,proper lubricants and proper spring pressure will let a flat tappet live.
Its your money though.
Keith
Re: Need advice: Flat tappet or roller in my hemi? [Re: polyspheric] #1343591
11/30/12 10:07 PM
11/30/12 10:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I check/adjust my lash often....
I do idle a lot cos it`s a street car that I race...
I`ve had zero problems except for TRACTION..........
Isky cam here, non agressive lobes, good tool room springs and ti retainers..........6+ years and one lifter rebuild........oh ya, stock unbushed lifter bores.............GO FOR IT!
Re: Need advice: Flat tappet or roller in my hemi? [Re: jamesc] #1343592
11/30/12 10:08 PM
11/30/12 10:08 PM
State of retirement
52savoy Online content
52savoy  Online Content
State of retirement
X1.. You can groove the (lower part)lifter bores with a tool from I believe CompCams. It allows a small amount of oil to leak by and spray on the cam lobes.
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343593
11/30/12 10:20 PM
11/30/12 10:20 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Absolutely solid roller, imo. Crower, Bullit or whatever cam
maker you choose should be able to make a grind that's easy
enough on your springs. You'll get better performance & reliability.
I flattened the solid flat tappet in my hemi after only 6 mos, so
roller next time.
Re: Need advice: Flat tappet or roller in my hemi? [Re: Triggerfish] #1343594
11/30/12 11:28 PM
11/30/12 11:28 PM
jamesc Offline
jamesc  Offline
roller next time.
it happens but it is not typical 2¢
Re: Need advice: Flat tappet or roller in my hemi? [Re: jamesc] #1343595
11/30/12 11:42 PM
11/30/12 11:42 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'd vote a solid roller all the way. I contacted Bullet Cams told them what I wanted, gave them the specs on the motor and the chassis. They delivered, I couldn't be happier with a product. Dave
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343596
12/01/12 12:10 AM
12/01/12 12:10 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
w/ 528 ci of Hemi, I'd be mad if it didn't run 10's.
Re: Need advice: Flat tappet or roller in my hemi? [Re: Mr.Yuck] #1343597
12/01/12 12:24 AM
12/01/12 12:24 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have done both with my Hemi, and its a matter of preferance. With proper break in and spring pressures & oil, a flat cam should last a long time. I am currently running a .608 lift solid mechanical and I have already had my little 484 pump gas hemi in the 10.90's.
Now I also ran roller cams for many years in my Hemi, and if you keep the lift mild, and use a good manufacturer, all will last a long time as well. As soon as you go looking for all that untapped hp with a roller, you find all the weak links in the valve train. Ask me how how I know. I went thru a lot of parts running a .750 lift roller on the street.
Its all preference..
Re: Need advice: Flat tappet or roller in my hemi? [Re: Mr.Yuck] #1343598
12/01/12 04:51 AM
12/01/12 04:51 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Good info from all you guys that actually run, or ran, each of them. On the roller side, are the $500 rollers sufficient, or do I need to be stepping up to the $1000 ones?
Re: Need advice: Flat tappet or roller in my hemi? [Re: fig426] #1343599
12/01/12 06:20 AM
12/01/12 06:20 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I went with Crane 66550-16 lifters with pushrod oiling and a crane cam that is 242@.050 and .608 lift with a 112 LSA, it idles great and with my 9.5 to 1 pistons its a great street/strip combo. Contact Chase Knight at crane for a recommendation. Tim
