Correct finish on transmission parts FOR 71 340 CUDA.. #1343497
11/30/12 02:42 PM
11/30/12 02:42 PM
Sweden
71redcuda Offline OP
Sweden
Hi everyone!
Need some help here. Would like to know the correct finish on the following parts below (see pic)..
For a 71 340 cuda.
Nr.1 What is the correct color of this for a 340 car? (Only 440 and hemis used the yellow paint?)
Nr.2 Factory finish for ALL mounting bolts for it?
Nr.3 Correct finish on the transmission bracket?
Nr.4 Correct finish for the 2 mounting nuts for the transmission bracket?
Nr.5 Factory finish for the 4 mounting bolts/nuts that holds the black bracket?
Thanks!
Nicklas
Re: Correct finish on transmission parts FOR 71 340 CUDA.. [Re: 71redcuda] #1343498
12/03/12 02:20 PM
12/03/12 02:20 PM
Sweden
Sweden
Anyone..
Re: Correct finish on transmission parts FOR 71 340 CUDA.. [Re: 71redcuda] #1343499
12/03/12 02:48 PM
12/03/12 02:48 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Pan bolts are phosphate
bellhousing bolts are phosphate
shifter pivot bracket nuts are phosphate
shifter pivot bracket is natural
