Re: cleaining the inside of a 8.75 housing [Re: mopowers] #1343472
12/03/12 01:42 AM
12/03/12 01:42 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I found a local blasting facility that is sand blasting the inside for $40. Heck of a deal if you ask me!!!
I was told to blast with caution, and not the inside. While blasting will clean the inside there will be little places where media (sand etc) sticks to the grease and you'll have a hard time seeing it or getting it out. Then it was clause issues with your diff down the road.
A solvent tank / Acid Dip process is a better route I think, as the grease is removed and the metal is clean.
If you have the outside blasted only seal up the housing really really well to prevent media from getting inside.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: cleaining the inside of a 8.75 housing [Re: BigDaddy440] #1343473
12/03/12 02:07 AM
12/03/12 02:07 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
-dan
There was no oil or grease on the inside. It was dry as a bone and rusty and scaly. The axle ends really weren't that bad. The axles came out pretty easily as did the axle seals. I'll hit the axle seal and bearing ends with a cylinder hone just to clean them up a bit. It'll be good to go.
Re: cleaining the inside of a 8.75 housing [Re: mopowers] #1343474
12/03/12 02:18 AM
12/03/12 02:18 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Run this though the rear end housing with a pool pump for a few hours...
Rust remover
Re: cleaining the inside of a 8.75 housing [Re: mopowers] #1343475
12/03/12 04:53 AM
12/03/12 04:53 AM
Go buy several cans of Easy Off oven cleaner and shoot it full inside and let it sit for several hours each time and then rinse it out, repeat as needed
Re: cleaining the inside of a 8.75 housing [Re: Cab_Burge] #1343476
12/03/12 10:19 AM
12/03/12 10:19 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Rust remover
I agree that this and other similar products like Evaporust and Unrust will do a great job, however if he can get it done at a machine shop for $40.00 they are typically going to cost more to get the job done based on the size of the rear end housing and the amount of those products needed to do the job, hence my suggestion to use the home brewed vinigar mix instead.
Re: cleaining the inside of a 8.75 housing [Re: Stanton] #1343477
12/03/12 01:28 PM
12/03/12 01:28 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I would think finding another housing would be easier and cheaper !!!
We found the Powerball winner!!!!! Priced one for an A lately? :-)
Re: cleaining the inside of a 8.75 housing [Re: pishta] #1343478
12/03/12 02:59 PM
12/03/12 02:59 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
It's interesting how people like to spend other's money. I'll happily take donations for a new one. But that ain't happening, so the next best is refurbishing this one. Once it's together, there'll be plenty of year of service left in this old housing.
