5.7 in a 98 dodge truck possible?
#1343429
11/30/12 10:54 AM
11/30/12 10:54 AM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
Dad was wondering if the 5.7's would bolt up to the original tranny and motor mounts in his 4 wheel drive 98 full size truck? Its just a 318 but only has 50-60K on it. He doesn't want to go buy a different truck to pull with if it is possible to just do an engine swap. I know the wiring is probably different and we were thinking that the plug and play harness' maybe that answer unless others know different.
thanks corey
Contact Me about AMD Prices
Re: 5.7 in a 98 dodge truck possible?
[Re: hotairballoonpilot]
#1343430
11/30/12 12:15 PM
11/30/12 12:15 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
no. it's not a bolt in swap.
has it been done? yes, with some minor fabrication work.
there may even be conversion mounts available on the market now, the few instances of guys putting 5.7 Hemi's into Dakota's that I know of, did it several years ago when the 5.7 hemi was still pretty new.
**Photobucket sucks**
[Re: 70Cuda383]
#1343431
11/30/12 12:16 PM
11/30/12 12:16 PM
70Cuda383
Marysville, O-H-I-O
Also, everything electrically will need to be touched as well. I think the 4.7 stuff is close, but not close enough. I think the guy took the computer, wire harness, engine, trans, and gauge cluster out of a donor truck and used that to swap everything into his Dakota
[Re: DusterMan]
#1343434
12/01/12 05:41 PM
12/01/12 05:41 PM
hotairballoonpilot
South Dakota
Don't think so. I think he is looking at the hemi idea. He has been a mechanic at the local dodge dealership for 48 years so driving the new hemis I think has him thinking that way.
