Re: lets see'm: your panhard with leaf spring setups!
[Re: dangina]
#1343381
11/30/12 02:15 PM
11/30/12 02:15 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Works great, did it back in '99. Didn't have a hoist then so no pictures of stuff like that, maybe some day. Might have a picture or 2 that I took of the axle end/brakes and such, but I don't know where they are, some I can't figure out where I put them.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#1343382
11/30/12 03:18 PM
11/30/12 03:18 PM
Posts: 27,598 So Cal
autoxcuda
So Cal
I put a RealXD mini cam under the rear of my car at Willow Springs Raceway to look how much rear end movement there was. Didn't look like much http://www.youtube.com/watch?v=hfMf9NzpY7Ehttp://www.youtube.com/watch?v=TLOrFexa6FkMaybe it would be better/easier to observe if I had a pointer and a white backgound or white bar going straight down from the frame rail next to the spring edge. Problem is, the rear end arcs in when in roll. And that would not be flexing movement, just natural movement.
[Re: autoxcuda]
#1343383
11/30/12 03:37 PM
11/30/12 03:37 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think if the level of grip is high enough a panhard bar would shine.
Mopar to the bone!!!
[Re: 72Swinger]
#1343384
11/30/12 03:59 PM
11/30/12 03:59 PM
autoxcuda
So Cal
Could be so. My 245/50/15ZR tires are very old.
Something new in 275/40/17 size (right side) is next..
[Re: cageman]
#1343387
11/30/12 04:31 PM
11/30/12 04:31 PM
autoxcuda
So Cal
Sweet, every one likes a bind that is impossible to find, makes for an exciting year chasing it!
So you've used panhard/J-bar with leaf spring and got a bind?
Is that due from the different arc movements of the panhard rod and the axle with leafsping arc when it rolls?
binds in circle track cars drive you nuts. One indication of them was when we would scale the car and it would not repeat after bouncing and rolling the car. Those made for long nights trying to figure out what was causing it.
[Re: TC@HP2]
#1343390
11/30/12 10:10 PM
11/30/12 10:10 PM
autoxcuda
So Cal
... FWIW, all the Dodge TA and Plymouth AAR race cars used watts or panhards.
At least the Dodge has decoupled rear shackles. Don't know about the AAR. Meaning the inner race is wider than the bushing so the leaf spring has freedom to move side to side. I think I have a picture somewhere...
[Re: autoxcuda]
#1343391
12/01/12 12:43 AM
12/01/12 12:43 AM
Posts: 1,443 NW Chicago suburban area
Mopar Mitch
I actually have a brand new Panhard rod set assembly that I've never installed onto my Challeneg for autocrossing. I'm aware of a 72 Camaro fellow autocrosser (past SCCA national solo II chamopion) who built his own panhard assembly and he swore that it really made a big difference once he finessed it to adjust the roll-center...his car and mine both ran with similar suspension stiffnesses, as well as Flex-a-Form fiberglass leaf springs (225/inch).... one of these days I'll tackle the installation. The setup I have came from the "California Moparts/Suspension" company ... purchased it ~1988?
I have studied and have pics of the Chall T/A Posey car having its Panhard bar.... and a 69 Vintage Dart TransAm car with the same... i'll try to post the pics...
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1343392
12/01/12 10:57 AM
12/01/12 10:57 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
doh! pics aren't working!
[Re: Skeptic]
#1343394
12/01/12 01:43 PM
12/01/12 01:43 PM
Posts: 4,396 The Pale Blue Dot
Skeptic
The Pale Blue Dot
How much side deflection do you get with leaf springs? Seems to me that it would be far easier to screw up the geometry than any minor benefit. I don't remember seeing anything about one in the MP Chassis book or Martin's suspension book. I'll look when I get home and post the results later.
O.K. I looked through both of them, the MP book mentions the Track Bar or Watts Link, but only for use with a 4 link/coil over suspension. Martin's book discusses override traction bars- a leaf/link arraignment. Both emphasize the need for the leafs to be flat @ normal ride height for handling packages. Seem to me that most of the benefit could be found with solid bushings in front and sliders in back.
[Re: autoxcuda]
#1343395
12/01/12 02:44 PM
12/01/12 02:44 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Please post a thread when you make the swap.
[Re: brads70]
#1343396
12/01/12 02:46 PM
12/01/12 02:46 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I bought all the " fixings" to do it but haven't installed it yet. Hyperco said it wasn't necessary? I'd like to see some pictures of others panhard bars too though.
A guy on FABO posted this when I asked about what to do with regards to updating my suspension.
[Re: amxautox]
#1343397
12/01/12 03:41 PM
12/01/12 03:41 PM
Mopar Mitch
OK.. let's see if these will post now (I just download a program to reduce pic sizes...) these are from the 69 Yellow Dart that runs vintage TransAm.. Road America 2011.
Mopar Mitch
[Re: Mopar Mitch]
#1343398
12/01/12 03:42 PM
12/01/12 03:42 PM
Mopar Mitch
there's one.. lets try another..
Mopar Mitch
