Page 2 of 3 1 2 3
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: sixpack4spd] #1343244
11/30/12 09:59 PM
11/30/12 09:59 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
My turn... I doubt it's the valve spring pressure. I run 105 seat pressure and around 350lbs open on a Lunati .600 solid lifter cam. I've ran those springs for 35 years and will continue to unless something changes drastically.
Did you check/cut the valve guides so the retainer doesn't bottom out at max lift?
Block decked any? Check pushrod scrub pattern?
If all that is good, I would agree with some of the others...ignition and or timing.
This might be pushing it a little.. but did you mash the pedal down all the way and check the carb?
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: 52savoy] #1343245
11/30/12 11:47 PM
11/30/12 11:47 PM
IMGTX Offline
IMGTX  Offline
I was thinking the same thing.
I had a car wouldn't get up into the RPM's and it was because the linkage on the carb would bind and not open fully. If the primaries do not open fully it will usually prevent the secondaries from opening at all. If it's vacuum secondary make sure the diaphragm is OK.
2nd thing to do is replace the points & Condenser. As said already, a bad condenser can cause weird problems but a weak points spring can cause the points to float at speed effectively preventing spark and becoming a rev limiter.
While your in the distributor compare the distributor cam to a known good one and make sure the distributor lobes aren't worn down. If you don't have a known good one post pics. Somebody on here will let you know. Don't forget to grease the point's rub block and distributor cam lobe.
I also had a dual point distributor that wouldn't run higher RPM's if one set of pints was disconnected.
If the Carb is opening all the way and the distributor is OK then check the cam timing. IMHO.
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: IMGTX] #1343246
12/01/12 05:24 AM
12/01/12 05:24 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
In 1981 Me and some friends put my freshly built 426 Sreet Hemi in one of their "The Rod Shop" ex-pro/stock Challengers for the summer. It ran pretty good considering it was just a street Hemi with a .690 Crane roller modded carbs. I think it ran some 10.0s and runnered-up a few times before I reclaimed the motor for my roadrunner.
My roadrunners first pass down the track(Trails), was 7 tenths slower than it was before the engine rebuild.. It should have picked up about a second after the rebuild.
A quick look at carb linkage work I did when the motor was first put in the Dodge brought the problem to light. I had tightened a screw too much and prevented the secondarys from opening on both carbs
I redid the linkage and went back out and ran 11 tenths faster. 10.60.
Big disappointment...Never knowing what that old Rod Shop car would have ran with a hopped up street Hemi.
9.00
ok.. what was problem again...
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: MrBelvedere2] #1343247
12/01/12 12:48 PM
12/01/12 12:48 PM
Warner Robins, Georgia
DusterMan Offline
super street
DusterMan  Offline
super street
Does your tach have a rev limiter on it? I had a friend that messed with his car for a few days would not rev over 2500. Someone turn the dial down. A thought.
Pete:
2003 Dodge Quad 2500 Hemi
69 RoadRunner 4 sp Alpine White
2019 Dodge Charger
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: MrBelvedere2] #1343248
12/01/12 03:30 PM
12/01/12 03:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I wonder if the lifter preload is set so tight it can't rev for holding the valves open when it revs Up?
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: Dodgem] #1343249
12/01/12 03:39 PM
12/01/12 03:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Single point distributor? What is your dwell? When reving the car in neutral past 4000rpm, what does the dwell change to? Is it going to zero?
Can you see any unusual pitting on the contact surfaces of the points? Are you using Accel or Blue Streak points?
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: jbc426] #1343250
12/01/12 07:38 PM
12/01/12 07:38 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Just off of what you posted, two areas I would look into first. The ignition system, particularly the mechanical advance. And your valve springs and retainer/valve guide clearances. Save possible carb problems after these checks and/or settings.
Food for thought.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: HYPER8oSoNic] #1343251
12/01/12 10:44 PM
12/01/12 10:44 PM
MD
p d'ro Offline
p d'ro  Offline
MD
I agree that it may be something simple like the linkage. Mine just had the throttle cable come loose and it wouldn't pull. Check that when gas pedal is down that linkage is wide opened.
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: p d'ro] #1343252
12/02/12 03:04 PM
12/02/12 03:04 PM
Texas
bogusracer Offline
bogusracer  Offline
Texas
As suggested before, check your carb for wide open with someone else mashing the pedal to the floor. If that's ok, check your fuel delivery system. Sounds like its running out of fuel. Could be as easy as a fuel gauge not reading correctly and not enough fuel in the gas tank (that happened to me at the Drag strip once). If you have enough gas in the tank, then check the fuel delivery system. Fuel pump pressure and delivery rate, possible clogged fuel filter, check to see if the pickup in the fuel tank has a sock filter that is collapsed or clogged up. Make sure you don't have too much rubber fuel line on the suction side of the fuel pump which might collapse as the pump suction increases as the rpm increases. Just a few suggestions here as you did not say there were any popping issues etc. in your initial statement concerning the problem. If it just noses over and doesn't pull and it did before, that's where I'd look.
Good Luck.
Bogusracer
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: bogusracer] #1343253
12/02/12 04:15 PM
12/02/12 04:15 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Just for fun check to make sure your coil is wired correctly. If it's hooked up backwards it will still work but will break down at higher rpms.
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: stumpy] #1343254
12/05/12 02:23 AM
12/05/12 02:23 AM
Davis, California, USA
MrBelvedere2 Offline OP
Hey guys, thanks for all the advice so far. I was able to work on the car tonight. I got my 750cfm holley double pumper, built by a pro for my engine. I also have firecore spark plug wires that are brand new, also new autolite 85 plugs gapped correctly. I also swapped my points distributor for a known-good pertronix distributor set up with a performance curve. I fired the car up,and it still will no go over 4,000 rpm. I would hate to think its the heads. This motor is pretty much brand new and has about 1500 miles on it.unfortunetly the place that built it is out of business. You rev it up and it sounds like it's running somewhere, just seems to hit a stop at 4,000 rpm. I did put new pushrods in it, they are the stock length. I do know the motor was decked enough to remove the stampings on the distributor pad. Would that be enough to warrant custom length pushrods? I was told when I purchased the motor to use stock length pusrods. I am running a hudraulic cam with stock stamped rockers. I'm running out of ideas.
1965 Plymouth Belvedere II hardtop
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: MrBelvedere2] #1343255
12/05/12 02:58 AM
12/05/12 02:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That explains your absence at tonights car club meeting...
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: Kern Dog] #1343256
12/05/12 04:07 AM
12/05/12 04:07 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
The way that you describe the probem, is the same thing that I went through two years ago with my 360. I had the 14 year old valve springs replaced. End of problem.
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: Mr. T] #1343257
12/05/12 04:48 AM
12/05/12 04:48 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That would mean the springs in MrBelvedere2's motor would have not be new. And really shot old springs at that. Maybe pull some valve springs and get them checked. And check if the valve guides are hanging up the valves.
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: MrBelvedere2] #1343258
12/05/12 04:53 AM
12/05/12 04:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Seems like you are going through the elimination process. Before I pulled the heads, I pull off the water pump housing, timing cover and check the timing chain marks.
Could be heads too. Pick your poison. I think checking the timing marks would be less costly in terms of parts.
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: MrBelvedere2] #1343259
12/05/12 10:49 AM
12/05/12 10:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm wondering if there is enough milling to be the problem.
I would check my cam degree first.
Did you check the old pushrods against the new pushrods for length!
really sounds like it is holding the valves open from pushrods too long,
You can buy a shim kit and shim up the rocker shafts .040 then .060 this cannot hurt anything worst it can do is tick.
http://www.hughesengines.com/Index/produ...mp;partid=10406
http://www.hughesengines.com/Index/produ...mp;partid=10404
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: Dodgem] #1343260
12/06/12 10:48 PM
12/06/12 10:48 PM
I would love to try those shims for the rockers, but the problem is this motor is an early big block with the 4-bolt max wedge style heads, and has the bolt-on rocker shaft post, not the casted-in style. Maybe I can just make some .040 shims from square stock and try it that way?
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: MrBelvedere2] #1343261
12/06/12 10:52 PM
12/06/12 10:52 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Mopar Action magazine had a blurb on that. They took .040 aluminum sheet and made the shims themselves.
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: MrBelvedere2] #1343262
12/07/12 11:00 AM
12/07/12 11:00 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea just shim the post up. .04 then .06
pop cans can be cut square and drilled for low buck shims thin so you have to stack some together!
Re: Motor won't rev over 4,000 rpm. Valve springs? [Re: Dodgem] #1343263
12/07/12 06:28 PM
12/07/12 06:28 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
however, I had a mishap once... mis-read the timing marks on the gears when I installed them. cam ended up about 30 degrees advanced. engine fired right up and ran great. but it would NOT rev over 3,000 rpm.
I did the same thing. It ran great, but at 3000, it just stopped.
Dennis
Page 2 of 3 1 2 3
