How about this Lunati cam?
#1342915
11/29/12 12:15 PM
11/29/12 12:15 PM
Posts: 143 Buenos Aires, ARGENTINA
madmax2
Does anyone use this Lunati cam? Code:
Solid, lopey idle. Lunati's version of the Purple Shaft cam with increased torque and horsepower throughout the power range.
Advertised Duration (Int/Exh): 270/270 Duration @ .050 (Int/Exh): 243/243 Gross Valve Lift (Int/Exh): .548/.548 LSA/ICL: 110/104 Valve Lash (Int/Exh): .018/.018 RPM Range: 2500-6500 Includes: Cam Only
Part Number: 30201011 Previoius Part Number: 404A1LUN
How about that for a SB 418 for the street? the rest of the combo is: Edelbrock heads, air-gap or Xcelerator intake, holley 750 vac-sec, rc 10:1, 4-speed manual and 3.54:1 gears. I would like to know your opinion, thanks.
'70 Dodge GTX sb 418ci (Early A-body), Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator, Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
Re: How about this Lunati cam?
[Re: Dodgem]
#1342919
11/29/12 04:38 PM
11/29/12 04:38 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
4 speed in at 104 you'll like it maybe even 103/102
I would not get to wrapped up in advancing that small cam with that many cubes. I'd be tempted to go to the next larger lobes on a 108lsa and stick it in around 104 as it will still make lot's of low end. I ran the 278,251@.050 .608 w 1.6 RR 108lsa 103 icl on a 408 and it was still loaded on the bottom end,ran mid 11's with a 2barrel carb and 2.50 rear gears 28" tires.No cage at the time.
[Re: goldmember]
#1342920
11/29/12 08:32 PM
11/29/12 08:32 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
Why a 2 bbl?? Why 2.50 gear??
[Re: madmax2]
#1342922
01/05/13 05:34 PM
01/05/13 05:34 PM
madmax2
What choose?
[Re: moparacer]
#1342924
01/05/13 06:07 PM
01/05/13 06:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What choose?
The Xcelerator intake if it were mine...
Dont quite get why anyone wants to run that small dual plane on any 400 + cid small block.
I see why... its a street car and the low end would be better... he will most likely never see more than 6000 rpm
[Re: moparacer]
#1342925
01/05/13 06:13 PM
01/05/13 06:13 PM
madmax2
I own both, the Xcelerator is used and the air-gap new in box
