70 Dart Hood Scoops Location #1342903
11/29/12 11:49 AM
11/29/12 11:49 AM
Oklahoma City, OK. USA
Dr. Red Offline OP
Dr. Red  Offline OP
Need some location specs for a 70 dart hood scoops. I got a great hood, but it's not drilled for the scoops. I do not have the original hood for comparison. So can anyone get me the measurements for the holes in the hood for the scoops? Thanks...Red. Also asked a question about a 70 challenger overhead console..
Re: 70 Dart Hood Scoops Location [Re: Dr. Red] #1342904
11/29/12 11:57 AM
11/29/12 11:57 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
the underside of the hood should already be pre drilled.
get the rear two holes on each scoop (arrow points tot he rear of the hood) perfectly centered and the rest of the holes line right up.. its really easy to do once you look at it..
get these two holes right and the rest is cake,
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: 70 Dart Hood Scoops Location [Re: abodyjoe] #1342905
11/29/12 12:10 PM
11/29/12 12:10 PM
Dr. Red Offline OP
Dr. Red  Offline OP
Thanks!, I thought that might be what those holes were for but needed to make sure.
Re: 70 Dart Hood Scoops Location [Re: abodyjoe] #1342906
11/30/12 02:02 PM
11/30/12 02:02 PM
Dr. Red Offline OP
Dr. Red  Offline OP
Thanks Abodyjoe: got em installed.
