Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: EL5 71] #1342556
07/15/13 05:11 PM
07/15/13 05:11 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
Here's a pic of it installed on your old car Troy. I know the fella Pete who owns her in New York now. There's a little tiny hole on the rad. support on Chargers for the upper attatching screw on the bottle bracket. It's pretty tough to even notice it there because that area is usually blacked out.
Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: EL5 71] #1342557
07/15/13 05:14 PM
07/15/13 05:14 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
Here's the Flasher. Same for Charger and Fury.
Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: EL5 71] #1342558
07/15/13 05:27 PM
07/15/13 05:27 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
Another R/T with the bottle bracket.
Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: EL5 71] #1342559
07/15/13 11:35 PM
07/15/13 11:35 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
Well, shiver me timbers !!!! I do learn something new every day and I need to go back to my stash, I think the bottle I have has the bracket !!!!
and Boy, you about tore my heart out with that picture !!!! I miss that car!!!
I take it he still has it then....... I hope so...... I need to get in contact with him for ole-time sake......
Troy
Houston Mopar Connection Club
Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: EL5 71] #1342560
07/16/13 10:42 AM
07/16/13 10:42 AM
Minnesota
billrabe Offline
billrabe  Offline
Minnesota
What is the flash rate for this flasher? It does not appear to be commonly available. It appears to be a two prong flasher and I would expect it is 12 volts and flashes only 1-2 times per second. From what I could tell from searching online, they were made by Tungsol in Newark, NJ or Ideal corporation of Brooklyn, NY. Also, the reservoir for the Fury appears to be different than the one for the Charger.
Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: billrabe] #1342561
07/16/13 05:49 PM
07/16/13 05:49 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
If I remember right, the flasher interupts the system so that the brushes cycle approximately 50 times per minute. Yes, the Fury bottle is quite different. It mounts over on the passenger's side on a Fury and it's a transluscent white color and completely different shape. The black plastic bottle that will work for the Charger and Imperial occasionally pop up for sale on E-Bay. I usually try looking in salvage yards for 71 Imperials and 71 Furys to get parts for the system. Sometimes you strike gold.
Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: EL5 71] #1342562
06/07/14 01:14 PM
06/07/14 01:14 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
Finally got one!!!! I have found a rare original 1971 Charger Headlamp Washer under dash harness with it's original part number tag. Here's a pic of the tag. It was falling almost completely off so I'll probably reproduce it. The harness I made in the photos above using only the factory wiring diagram was nearly perfect except it was a few inches short. Part number is not in my 1970-71 Parts Book but other headlamp washer parts are. I find this a little strange because it is a separate harness all by itself and not incorporated into the main under harness assembly. Photos of the original harness coming shortly. It is basically the same as the one above, just about a foot longer.
Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed [Re: EL5 71] #1342563
06/07/14 07:11 PM
06/07/14 07:11 PM
Houston, Tx
Houston, Tx
Excellent news Ed!! ...
Does the owner you know of Whitey still own her?
Troy
