Re: 440 running rough.....need some help
[Re: scarface06]
#1342371
11/28/12 12:22 AM
11/28/12 12:22 AM
RapidRobert
the compression readings tell me the long block is healthy, the dist has been swapped, all that is left is the intake/carb (vac leak) & plugs/wires & if the plugs/wires are good & if sure of no vac leaks then that only leaves the carb & if this is this the infamous eddy 1407 . I would pull the top off & see what you see & maybe take it apart & spray it with a cleaner then blow it clean with shop air. Holler how things turn out. EDIT does it have the same ECU when you switched ignitions? What color is it?
[Re: scarface06]
#1342372
11/28/12 12:44 AM
11/28/12 12:44 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
The top bushing in the distributor is good no play?? Firing order is right? Distributor cap new and check for dizzy shaft moving up and down. may need a dizzy collar to stop pump drive gear from jumping up and down have another carb to try look at the step up springs with it running to see if they are bouncing up and down. vacuum advance is on ported vacuum better yet disconnected till it's sorted out. you sure no vacuum leaks underneath intake. just some places to look if the timing chain is tight!
[Re: scarface06]
#1342376
11/28/12 11:52 AM
11/28/12 11:52 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Have you confirmed that the damper ring hasnt slipped and the timing isnt where you actually think it is? Confirm the zero mark on the damper with TDC on cylinder #1?
This sounds more like a timing/ignition/firing issue.
Good battery voltage?
RIP Monte Smith
[Re: Mr.Yuck]
#1342378
11/28/12 12:11 PM
11/28/12 12:11 PM
scarface06
Didn't check the ballist yet, but did run 12 volt direct to coil to try it but no difference. It's not like it sat for a couple months and now not running good. It was running great one day, then the very next day it went to hell. Also I did check the dampner.. within about 2 degrees.
[Re: scarface06]
#1342379
11/28/12 12:45 PM
11/28/12 12:45 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
try spraying carb cleaner while its running & see if it smooths out,if it does,then vac leak or the carb,i am betting on a carb problem
[Re: CSK]
#1342380
11/28/12 12:54 PM
11/28/12 12:54 PM
scarface06
Tried that the other day and it wanted to die. Did not help, only made it worse.
[Re: Prodart440]
#1342382
11/28/12 01:38 PM
11/28/12 01:38 PM
CSK
Pattison Texas
is it just at idle ? or all rpms
[Re: Prodart440]
#1342383
11/28/12 02:21 PM
11/28/12 02:21 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Dirty fuel filter??
that will do it...or dirty fuel sock
[Re: Prodart440]
#1342384
11/28/12 03:21 PM
11/28/12 03:21 PM
scarface06
Dirty fuel filter??
new clear filter, complete line has blown out when tank was dropped. I know it does it at idle to 3000RPMs while sitting in the garage. Will drive it on the highway today. Sure does suck to get it back after 7 years just to have it sitting
[Re: scarface06]
#1342385
11/28/12 03:30 PM
11/28/12 03:30 PM
CSK
Pattison Texas
while its running look down the carb & see if you can see fuel dripping
[Re: CSK]
#1342386
11/28/12 03:48 PM
11/28/12 03:48 PM
scarface06
I'm guessing you want me to check to make sure there is fuel coming only from where is is supposed to? I'll check that later today as well.
