Ill try again, 64, earlie 65 dodge HPP d100 parts #1342263
11/27/12 05:59 PM
11/27/12 05:59 PM
Finally a HUSKER again
Moparnut426 Offline OP
OK, I have asked on here sooo many times I feel anoying by this time, but I am still seriously searching for the correct shifter bezel for this truck. Its completely different than any other cable shifted dash mounted bezel we have found, and we have bought MANY! This one has got a little shorter spacing than any of the other bezels we have. I dont have any measurements right now, but I will get them tonight from my uncle.
The bezel we thought was correct was off of a 65 dodge d100 with a 318 and a cable shifter 727, well it was correct in every way except the throw distance.
It was longer. So I am asuming the 426 wedge or big block trucks used a special setup, and since there are so few out there I cant find one. I dont know if there ever was a 383, or 361 powered d100 with an auto in it, but I would think that one would work.
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: Moparnut426] #1342264
11/28/12 01:01 PM
11/28/12 01:01 PM
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: Moparnut426] #1342265
11/28/12 01:10 PM
11/28/12 01:10 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I would think Ben would be able to help:
http://www.customsportsspecial.com/
I'd love to see pictures!
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: wally426ci] #1342266
11/28/12 03:22 PM
11/28/12 03:22 PM
Gainesville, FL
CSSRegistry Offline
CSSRegistry  Offline
Gainesville, FL
Hey Shawn - Kasey and Chris are in the registry and we've been trying to locate this bezel for a long time now.
i'll see if i can dig up the photos they sent me a while back and post 'em up.
Ben
1963-1967 Dodge Custom Sports Special and High Performance Package REGISTRY
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: CSSRegistry] #1342267
11/28/12 03:28 PM
11/28/12 03:28 PM
Gainesville, FL
CSSRegistry Offline
CSSRegistry  Offline
Gainesville, FL
photo of bezel - the original is on the right side of the photo.
note the difference between the shifter positions.
You can see the one on the right is the original. the lip for park on the original is 1/4 lower than the one on the left. 1" on original and 3/4 on the other I have. I do not see where I can adjust the shifter to fit the other.
Ben
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: Moparnut426] #1342268
11/28/12 11:41 PM
11/28/12 11:41 PM
Canada
demon Offline
demon  Offline
Canada
my guess is the bezel difference is between the dual cable shifter used in 65 and the single cable shifter which was used from 66-68 in trucks, and many other 66 and later vehicles like A100's and motorhomes etc. Since 1961-1964 pickups had a pushbutton, 65's had a dual cable dash shift and 66-68 pickups had a single cable dash shift that would make the 65 version quite uncommon. One year deal.
There should be no difference in the shifter between big blocks and small blocks or even slant 6's since they all had 727's at that time. The reason they went to a single cable shifter in 66 is because Chrysler switched to the "modern" 727 with the lever and internal park linkage in 66 across the board. Until 64, the transmissions had no park with only the small trans mounted drum park brake in light trucks, and in 65 they transmission had the cable operated park mechanism like was used in the 62-65 B body cars and 63-65 C bodies
The throws on the two types of dash shifters were different so it makes sense that the detents int he face plate would be different too.
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: demon] #1342269
11/29/12 12:55 AM
11/29/12 12:55 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Do you know Jim or maybe Tim Welters in Verona, Missouri? He has a few CSS trucks and may know the answer to your questions. I have his info around here somewhere... I think it is Tom Welters, he runs Welter's Farm Supply.
JB Rhinehart, Realist
A-Body's RULE!
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: Rhinodart] #1342270
11/29/12 09:16 AM
11/29/12 09:16 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
And Terry over in Washington has a ton of trucks in his yard. Maybe he can help.....
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: wally426ci] #1342271
11/29/12 04:46 PM
11/29/12 04:46 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Why do they have 2 slots in them? Is there a part that goes over the top of what is shown in your picture?
Here is a picture from a 66 HPP truck.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: Soopernaut] #1342272
11/29/12 04:55 PM
11/29/12 04:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The slot is probably for the park lever ???
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: JohnRR] #1342273
11/29/12 04:59 PM
11/29/12 04:59 PM
Gainesville, FL
CSSRegistry Offline
CSSRegistry  Offline
Gainesville, FL
i think the early levers had a back-lit strip that indicates the gear.
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: CSSRegistry] #1342274
11/30/12 10:13 AM
11/30/12 10:13 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I did see that some of them are lighted.
I believe Demon is right about the 65 using a different bezel than 66-68 trucks.
When in doubt, check the parts book. Find the number on the bezel and compare it to your VIN and it'll tell you which is correct. There isn't a separate one listed for HPP trucks or anything.
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: Soopernaut] #1342275
11/30/12 11:25 AM
11/30/12 11:25 AM
THANKS guys, now were on to something! I was racking my brain as to what the difference is, but the dual cable, TOTAL PAIN TO SET UP, is in this truck, and the Truck has a park, so thats more than likely the answer here.
Id love the infor to these two guys. Maybee I could get ahold of them and get what we need. Would be a great christmas gift to my favorite Uncle in the world!!!
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: Moparnut426] #1342276
12/03/12 01:27 PM
12/03/12 01:27 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Ok, here is Bud Thorpe's email. He has alot of trucks that he parts so maybe try him:
powerwagon54@hotmail.com
I PM'd Terry for you.
Re: Ill try again, 64, earlie 65 dodge HPP d100 parts [Re: wally426ci] #1342277
11/20/13 09:11 AM
11/20/13 09:11 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Just bringing this back up. I've found quite a few hard to find NOS parts at arizonaparts so maybe Martin could have this part. Just need the part number off of the back...... and search.
