e body hemi choke #134187
10/09/08 10:35 AM
10/09/08 10:35 AM
Anonymous OP
Anonymous OP
can someone out there please post a picture of where the choke cable comes out of the firewall for a hemi powered e-body??? im building a 70 clone...THKS!!!!!!!!!!!!
Re: e body hemi choke #134188
10/09/08 10:47 AM
10/09/08 10:47 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
70 Hemi's did not use a manual choke, that was 1971 only. Your car should have an automatic choke.
Re: e body hemi choke [Re: ScottSmith_Harms] #134189
10/09/08 10:52 AM
10/09/08 10:52 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Off the carb
Re: e body hemi choke [Re: ScottSmith_Harms] #134190
10/09/08 11:04 AM
10/09/08 11:04 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is the choke cable on an original 1971 Hemi Cuda, the dimple to the left is where they would typically come through but this example just used the single hole for both cables, the hole on the right was normally used soley by the Shaker cable. I guess the line worker got lazy that day and just decided to use one hole, you'll notice they were a bit sloppy with this car, niether the hard brake line or the wire harness were even hung through thier respective clips! This pic is of a low mile one owner "Survivor" it's never been altered.
Re: e body hemi choke [Re: ScottSmith_Harms] #134191
10/09/08 11:48 AM
10/09/08 11:48 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Scott,
How big were both holes ?
Shaker cable hole ?
Choke cable hole ?
logan426
Re: e body hemi choke [Re: ScottSmith_Harms] #134192
10/09/08 01:15 PM
10/09/08 01:15 PM
Anonymous OP
Anonymous OP
great...thk you....
Re: e body hemi choke [Re: MLR426] #134193
10/09/08 01:48 PM
10/09/08 01:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
a, I measured one once and posted it with the measurement on Moparts a million years ago, I can't find the pic right at the moment but it was right around 3/4"-7/8"
Re: e body hemi choke [Re: ScottSmith_Harms] #134194
10/09/08 02:34 PM
10/09/08 02:34 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Thank you, Scott. Welcome aboard Texas Hemi..
logan426
