CRATE ENGINE HELP #1341837
11/26/12 08:19 PM
11/26/12 08:19 PM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
I just installed a indy crate engine 500 wedge for a friend of mine at low rpms it run rough and will not idle.When i rev the engine it slow about returning to lower rpms. It revs quick i don't think it is fuel problem i have changed the carb and it still the same.It came complete carb,dist, every thing was set on dyno ? it has a chrysler dist. I tried to call Indy twice but they pass me off afew times and then they say they will call me back.I would like some advice where to start troubleshooting at . like i said i have already swap card and checked air gap in dist. checked orange box and made sure of good gound . i have not moved timing i checked it at 2000 rpms and it checked out to be 38o any advice would be welcome.
Re: CRATE ENGINE HELP [Re: ringo440] #1341838
11/26/12 09:10 PM
11/26/12 09:10 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Sounds like the advance springs are too light or its sticking in the advance position,vacuum leak my cause that too
Re: CRATE ENGINE HELP [Re: 500ciDuster] #1341839
11/27/12 07:52 PM
11/27/12 07:52 PM
ga
ringo440 Offline OP
ringo440  Offline OP
ga
Thanks for your reply
500ciDuster
this is what i found to be the problem. the distributor shaft is spline together under the weights it has striped out the splines.
brand new dist ?
Re: CRATE ENGINE HELP [Re: ringo440] #1341840
11/27/12 10:28 PM
11/27/12 10:28 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
Cool, sounds like it needs one or new parts
Re: CRATE ENGINE HELP [Re: 500ciDuster] #1341841
11/27/12 10:44 PM
11/27/12 10:44 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Paging Josh King, please answer the peach phone...
