condensation inside new Ram truck question
#1341822
11/26/12 08:04 PM
11/26/12 08:04 PM
Posts: 282 USA
ignoble
USA
I have a '11 Ram 3500 4 door with a slider back window. Now that it's getting colder here, i notice a LOT of condensation on the inside of the windshield when i get in in the morning. Literally have to wipe it with a towel or the defrost would take forever. I don't remember near as much last year ? Is it just from trapping the warm air in the truck when i get out, than it cooling overnight ? I've had plenty of old rigs that probably didn't seal as well, and none seemed to moisten the inside windshield as much. Is it due to the new "triple sealed" door weatherstripping they pimp in the advertising ? Part 2 of question : Yesterday morning I sat in the truck for awhile with defroster on until it warmed up inside, than shut truck off . About an hour later went back to truck to take family to the store -- In the space between the rear door edges, and the slider window, but only high in the corners at the headliner, both sides were wet. Visibly wet, touch it and it was like wringing a sponge.
This morning it was gone. So today I sprayed the upper corners [and all over] of the rear window with a hose, and both rear doors for a few minutes, and...Nothing, no sign of a leak. Is it just forcing the wet air to the upper back corners of the truck when the defrost is on ?
Any suggestions or similar experiences? I'm thinking of letting all the hot air out of the truck to equalize temps with the outside air each night, [ by opening the doors for a few minutes] --but this is often unpractical since i'm in Seattle area and half the time its raining.
The only other thing i can think is a got a "rock strike" star in the windshield a few months ago, about a 1/3" across, but you can't feel any blemish from the inside of windshield. Thanks for your thoughts.
Re: condensation inside new Ram truck question
[Re: ignoble]
#1341823
11/26/12 08:50 PM
11/26/12 08:50 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Yes, warmer moister air is what it's from. If you run the vents on full cold for a couple minutes to evacuate all of the warm moist air it will be a lot better. However if the cold air is also humid enough (due to the weather at the time) you're going to get condensation no matter what.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: topside]
#1341826
11/27/12 08:04 AM
11/27/12 08:04 AM
Posts: 282 USA
ignoble
USA
Thanks Topside. I have always used outside air and not recirc. I'll try engaging the A/C while in the defrost mode as you suggested. You'd think i'd know this stuff after living in this wet NW climate for 20yrs... Seems like the older i get , the dumber i realize i am !
[Re: 300rag]
#1341829
11/27/12 02:11 PM
11/27/12 02:11 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
... I'll try engaging the A/C while in the defrost mode as you suggested ...
On any vehicle I have owned, the AC compressor is engaged in defrost automatically. You can check by just listening for engagement as you adjust the control from heat to defrost.
That is correct. Ron
[Re: GO_Fish]
#1341833
12/02/12 02:03 AM
12/02/12 02:03 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
This is true with more modern vehicles, but does it hold true for old school stuff? I'm thinking (maybe incorrectly) that defrost with compressor running came to be common in the '80's???
It does not engage automatically in defrost on my '86 Toyota Supra. I have to specifically turn on the A/C. It DOES turn on automatically on my wife's '92 Acura Vigor, FWIW.
