What Causes Cracks In A Torque Converter Snout? #1341711
11/26/12 03:36 PM
11/26/12 03:36 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
What are the typical reasons that a converter will have cracks in the converter snout?
Re: What Causes Cracks In A Torque Converter Snout? [Re: YO7_A66] #1341712
11/26/12 04:14 PM
11/26/12 04:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Had that happen on my drag car once, never did find a cause except the weld had started to fail. Didn't suspect any problem until it puked some ATF during a pass.
It was an old Turbo Action 4400stall in a footbrake SB/904 Duster that by then was in the 10s. Converter probably had hundreds of passes on it.
Sent it to Dynamic for repair and had them raise the stall speed, and it's been fine ever since.
Re: What Causes Cracks In A Torque Converter Snout? [Re: topside] #1341713
11/26/12 04:23 PM
11/26/12 04:23 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
They both appear to be full length from the square cut at the end of the snout back to the base on both sides.
Thanks for your reply.
Re: What Causes Cracks In A Torque Converter Snout? [Re: YO7_A66] #1341714
11/26/12 04:46 PM
11/26/12 04:46 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Top reason i have seen is from improper removal of the transmission. Ive seen folks try to remove the transmission without unbolting and pushing back the torque converter... that can put the weight of the tranny on the snout/tabs and crack it or snap em off...
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: What Causes Cracks In A Torque Converter Snout? [Re: G_T] #1341715
11/26/12 05:18 PM
11/26/12 05:18 PM
scratchnfotraction Offline
did this 2x myself, not a good idea to hang any weight on the TC hub during R&R. but in the JY I figured I was getting a new reman from the get go.
sound like you found the noise on start up...no?
Re: What Causes Cracks In A Torque Converter Snout? [Re: G_T] #1341716
11/26/12 05:18 PM
11/26/12 05:18 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I had the engine supported to the floor, and I unbolted the flex-plate before I unbolted the tranny which was supported by the jack. I did have a leak that was coming from the front of the tranny before I pulled it out. I believe that I pulled the tranny correctly.
Thank you for the reply.
Re: What Causes Cracks In A Torque Converter Snout? [Re: YO7_A66] #1341717
11/26/12 05:25 PM
11/26/12 05:25 PM
thats good,I did not think you broke it on R&R,just saying it can happen. I am sure it was broke causing the leak and noise before you removed it.
I have seen them get broke on install just as ez,and I have had a lot of 904 TC snouts fail from hard abuse on daily drivers.
some time it wears and just gets weak or from being remaned at the TC shop.
Re: What Causes Cracks In A Torque Converter Snout? [Re: scratchnfotraction] #1341718
11/26/12 05:26 PM
11/26/12 05:26 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
The startup noise/vibration/front leak, and the slipping in forward gears issue seems to point towards the torque converter.
The tranny is at the shop right now, so I should find out for sure in a few days.
I will admit that I am very hard on the car. I would never be accused of driving it gently.
Thank you both.
Re: What Causes Cracks In A Torque Converter Snout? [Re: YO7_A66] #1341719
11/26/12 05:55 PM
11/26/12 05:55 PM
a broke TC snout would do all that for sure.
I have had a lot more 904 TC break the snout than 727s. one of the reasons I think the 904 went to the solid hub with machined flats to drive the pump over the notch/tang set up.
good luck,hope there is no more damage other than the TC.
Re: What Causes Cracks In A Torque Converter Snout? [Re: YO7_A66] #1341720
11/26/12 05:57 PM
11/26/12 05:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The lack of any radius in the corners of the slots contributes to the tendency to crack there.
Re: What Causes Cracks In A Torque Converter Snout? [Re: scratchnfotraction] #1341721
11/26/12 05:59 PM
11/26/12 05:59 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thanks, but I think there is one more internal issue. The trans locks up while pushing it forward in N (engine off). Then when I push the car backwards about a foot or so and then push it forward again, it frees itself up. Possible broken sprag is the guess so far.
John:
Thanks for your reply. The crack started right where you said.
Re: What Causes Cracks In A Torque Converter Snout? [Re: YO7_A66] #1341722
11/26/12 10:52 PM
11/26/12 10:52 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
When I was in High School, I cracked the snout on a 904 behind a 318 duster. I was dogging it, liked to downshift manually when coming to a stop light so the engine would gurgle back pressure like a stick. There were a few times that I barked the tires by downshifting at too high a speed (and kissed the steering wheel)... and then came the cracked snout! Since then I've run 904's hard without any problems (and letting them downshift themselves).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: What Causes Cracks In A Torque Converter Snout? [Re: YO7_A66] #1341723
11/27/12 09:59 AM
11/27/12 09:59 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
causes? high torque, sticky tires, heavy car, tall gearing....if this a 904 trannny? not uncommon behind a 360 or larger motor...
in my 3950lb 5th ave that I had 3.55's and an A500 in behind a 360 and 255/50R17 BFG KDWS's, the TQ had cracks starting at the corvers of the pump drive slots. never hung the weight of the tranny off of it, but had a fair amount of heavy acceleration, and those tires hooked pretty well....
2017 Grand Cherokee Overland
Re: What Causes Cracks In A Torque Converter Snout? [Re: patrick] #1341724
11/27/12 09:45 PM
11/27/12 09:45 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I 2nd what john said cuz the snout just runs the pump,I've only seen the 904's do this and the A500's changed the pump engagement area
