Re: What size carb???
[Re: mopowers]
#1341654
11/26/12 02:50 PM
11/26/12 02:50 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Yes a 750 is way too big for most applications. A 750 would be more suited for a 440 and some people even use them on BB strokers! If I were you, I'd go with a 600 for stock/mild 340 or maybe a 650 IF the 340 is a pretty wild. Sounds like a 600 would be fine for your application. Overcarbing will make the motor a slug down low...
[Re: mopowers]
#1341658
11/26/12 09:23 PM
11/26/12 09:23 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Can you tell us more about the 750 that you already have? What converter and gears do you have?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: mopowers]
#1341662
11/27/12 07:33 AM
11/27/12 07:33 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
How can a 750 be to big when the 340-6 engines had over 1300 CFM? A 750 properly jetted would be fine. A 600 would have better throttle responce on the bottom end but lack on the top end where the 750 would still be working..
I am truckless..
[Re: terzmo]
#1341671
11/30/12 01:05 PM
11/30/12 01:05 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Is the 750 comparable to a funnel and gas can? I don't think I've ever run anything on my 340's smaller than a 750 Holley. If you can tune it, a 750 will run fine on even a stock 340. If you have a 750, run it and see how you like it.
[Re: RobX4406]
#1341672
11/30/12 01:32 PM
11/30/12 01:32 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
That's what I'm gonna do. Just wish it was a vac sec 750 and not a double pumper. Maybe i can get someone to trade me for a 650 DP.
