71 CUDA PROSTREET #1341364
11/25/12 11:33 PM
11/25/12 11:33 PM
cudaman440_1 Offline OP
Im building a 71 cuda engine 493 auto trans dana 60
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341365
11/25/12 11:34 PM
11/25/12 11:34 PM
Where's the car pics?
Re: 71 CUDA PROSTREET [Re: ] #1341366
11/25/12 11:37 PM
11/25/12 11:37 PM
They are coming
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341367
11/26/12 01:55 AM
11/26/12 01:55 AM
Here's the motor a 493 with indy 440-1 heads,I had it in a 72 cuda the best time in the 1\8 mile was 6.13 not bad for 3200 lb car
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341368
11/26/12 02:01 AM
11/26/12 02:01 AM
engine
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341369
11/26/12 11:31 PM
11/26/12 11:31 PM
THE CAR, IT NEEDS HELP
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341370
11/26/12 11:45 PM
11/26/12 11:45 PM
FRONT,Check out disc brakes
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341371
11/26/12 11:52 PM
11/26/12 11:52 PM
Front
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341372
11/27/12 12:02 AM
11/27/12 12:02 AM
pic
Re: 71 CUDA PROSTREET *DELETED* [Re: cudaman440_1] #1341373
11/27/12 12:47 AM
11/27/12 12:47 AM
Post deleted by cudaman440_1
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341374
11/27/12 12:57 AM
11/27/12 12:57 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
The floor got to be replaced
With a "42" football jersey?
Re: 71 CUDA PROSTREET [Re: MuuMuu101] #1341375
11/27/12 01:09 AM
11/27/12 01:09 AM
oops
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341376
11/27/12 01:25 AM
11/27/12 01:25 AM
The back
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341377
11/27/12 02:18 AM
11/27/12 02:18 AM
So lets hear the rest of the plan for the car, tire sizes, cage, paint. I love custom projects.
Re: 71 CUDA PROSTREET [Re: ] #1341378
11/28/12 12:19 AM
11/28/12 12:19 AM
more rust
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341379
11/30/12 01:24 AM
11/30/12 01:24 AM
I tried a 12 inch slick on 11 inch wheel today im going narrow the rearend about 4 or 5 inches
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341380
11/30/12 01:41 AM
11/30/12 01:41 AM
next pic
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341381
11/30/12 10:25 PM
11/30/12 10:25 PM
I tried welding sheet metal today.This will take practice alot of practice look like butt welding is going to be the hard part.
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341382
12/01/12 12:06 AM
12/01/12 12:06 AM
Be very patient and do not try going to fast as you will end up with warped panels. This also applies to grinding the welds, it is so easy to over heat and again warp the panels. Practice on scrap for awhile first. It is very easy to get frustrated and pooch things up. Keep the regulator set at between 20 and 25, the gas does not last long in a bottle. Good luck
Re: 71 CUDA PROSTREET [Re: ] #1341383
12/01/12 02:12 AM
12/01/12 02:12 AM
I practice a little more tonite im getting better
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341384
12/01/12 02:48 PM
12/01/12 02:48 PM
A friend came by today with his 72 cuda 383 4 speed.
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341385
12/03/12 01:45 AM
12/03/12 01:45 AM
I have extra holes drill in the radiator support on 71 cuda.Anyone have pics
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341386
12/19/12 12:02 AM
12/19/12 12:02 AM
I got to work the cuda a little this week. Dang rust had to remove
the cowl but it will be worth it. i was thinking light racecar but how im leaning toward street car now
Re: 71 CUDA PROSTREET [Re: cudaman440_1] #1341387
12/19/12 12:07 AM
12/19/12 12:07 AM
pic
