Converting Mopar Alternator to 1 wire???? #134121
10/08/08 11:41 PM
10/08/08 11:41 PM
Anonymous OP
Anonymous OP
...Can this be done. I know they can now be purchased from Powermaster, but what do they do to convert them, and can it be done easily and cheaply? I want to keep the Mopar 'LOOK' under the hood or I would just use the Delco 1 wire I already have. It must be possible, but what does it take? thanks guys/gals.
JJ
Re: Converting Mopar Alternator to 1 wire???? #134122
10/09/08 05:41 AM
10/09/08 05:41 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
A one wire has a voltage regulator built in the unit. I dont think a stock mopar case has the room for it.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Converting Mopar Alternator to 1 wire???? #134123
10/09/08 07:12 AM
10/09/08 07:12 AM
NORTH EAST OHIO
HEMIXPRESS535 Offline
NORTH EAST OHIO
Summit sells a 1 wire mopar alternator by powermaster, or a good alternator rebuild shop can do the conversion for you,
Thanks Kevon
Re: Converting Mopar Alternator to 1 wire???? [Re: HEMIXPRESS535] #134124
10/09/08 09:48 AM
10/09/08 09:48 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
the power master has a regular mounted on outside the case.
Re: Converting Mopar Alternator to 1 wire???? #134125
10/10/08 04:27 PM
10/10/08 04:27 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
JJ
Not sure I understand your question. If you are talking about the 17509 alternator, yes you can. The two wires on the 70's era alternator were for 12V and for the regulator. Hook the single wire to one field terminal and hook the other terminal by way of a short jumper to ground.
Craig
Re: Converting Mopar Alternator to 1 wire???? [Re: denfireguy] #134126
10/10/08 05:32 PM
10/10/08 05:32 PM
St. Catharines, ON
N
NewMemberAgain Offline
super street
super street
N
St. Catharines, ON
I have that one myself except w/o the fancy chrome
Two things; Yes it has an external regulator, it really looks like an eyesore, but it does wire up very easily.
Secondly, it does not charge at idle. At least that is what the paper bench tested it at. Also when I idle my car no charge. TILL it hits 2000 rpm, THEN it charges.
So it is coming off the car, and we will re-evaluate my charging system over the winter.
Make sure you havea good return policy, you may need it IF the same thing happens to you!
Bryan
Re: Converting Mopar Alternator to 1 wire???? #134127
10/10/08 05:49 PM
10/10/08 05:49 PM
AndyF Offline
AndyF  Offline
Why would you want to convert a Mopar alternator to one wire operation? When you do that you lose the capability of the alternator to properly regulate the voltage of the wiring system.
I understand why guys with race cars who have very simple wiring harnesses run a one wire alternator but I can't think of a good reason to hack up a Mopar alternator that way.
Re: Converting Mopar Alternator to 1 wire???? [Re: AndyF] #134128
10/10/08 06:58 PM
10/10/08 06:58 PM
streetglide Offline
streetglide  Offline
I was wondering this my self. How does a one wire Alt. know when your electrical system needs more or less juice. Is it constantly charging to the point of boiling over your battery?
69 Dodge Coronet 77 Dodge M880 84 Jeep J20
Re: Converting Mopar Alternator to 1 wire???? [Re: streetglide] #134129
10/11/08 04:15 PM
10/11/08 04:15 PM
streetglide Offline
streetglide  Offline
Bump
Re: Converting Mopar Alternator to 1 wire???? [Re: streetglide] #134130
10/11/08 07:44 PM
10/11/08 07:44 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The difference is in the logic of controlling the alternator. In the older system, a voltage sensitive relay controlled the current on the field. When the voltage came up to the level of full charge on the battery, the relay would open up a set of contacts feeding 12 V to the field. The field would de-energize and the output current would cut off. When the voltage went down, the relay would release and the normally closed contacts would once again engage, current flowed through the field and output resumed. This is why there is light flicker and amperage flicker on the old systems. Where does the other field wire go? It is connected directly to ground by the second field brush.
The newer, so called "electronic" system (they both use electronics, just one is mechanical) used a transistor to control the voltage on the field. The transistor was inserted between the field and the ground. The other end of the field was now connected to 12 volts from the ignition. The transistor is an amplifier and conducts in a pretty linear fashion dependent on the voltage on the base of the pass transistor. It is the silver diamond shaped thing on the heat sink of the regulator. Since it is linear and continuous, the flicker is gone. No moving parts, less chance for failure and no flicker. A genuine improvement.
So there is actually two wires on the old system too, just one is going straight to case ground on the back of the alternator.
Both of them just used ignition voltage to see where the level of charge was on the battery.
Hope this helps clear it up a bit. Maybe more than you wanted to know.
Craig
