Re: I need a soldering iron recommendation...
[Re: Quicksilver440]
#1341113
11/25/12 05:13 PM
11/25/12 05:13 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Multiple splices of 10-18 ga wire.... For that sort of soldering I leave the soldering iron on the bench & grab my micro-torch... You need allot more heat than you'll get out of a soldering iron... For normal soldering I use my Weller workstation... Cleaning & tinning the tip regularly helps allot..
#1341114
11/25/12 05:18 PM
11/25/12 05:18 PM
RapidRobert
I just went thru this. I'd recommend finding a very large soldering iron (not a gun) or a small butane torch. The trick for me was to solder with NO wind and clean & tin the tip requently & use small clip on heat sinks that look sorta like nail clippers on either side to keep the heat from traveling & melting the insulation and getting the joint hot as quick as you hold it secure/TIGHT/steady & working with clean wiring strands all to avoid burning the wire dark which hinders heat transfer. EDIT missed the gauge you are working with yes you need a butane mini torch
[Re: pishta]
#1341122
11/25/12 09:49 PM
11/25/12 09:49 PM
Posts: 1,443 Maryland
Dads426
Maryland
Weller 8200. Been using them since the 1960's. I have 3, one in the workshop, garage and spare (I use them every day) They are on ebay all the time. Radio Shack sells the tips. Buy a cheap Harbor Freight heat gun for heat shrink tubing.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: ahy]
#1341124
11/26/12 12:46 AM
11/26/12 12:46 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Mine I got from SnapOn like 25 years ago.Has tips that you can change.It was like 40 bucks then.Still works great and if a tip goes bad you just buy new ones.I even soldered a few pin holes in my 65s gas tank with it.Rocky
Chrysler Firepower
[Re: jlatessa]
#1341127
11/26/12 11:08 AM
11/26/12 11:08 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
For splicing I use a method we had where I used to work called mousing sp?
You take a few strands of the same wire you're splicing and wrap it tightly around the joint, takes some practice but helps keep the joint from moving as you solder.
Joe
Brilliant. That's always my biggest problem. Thank you!
#1341130
11/26/12 12:18 PM
11/26/12 12:18 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Resistence soldering is a good trick to know http://www.brunelhobbies.com.au/soldering/instruct/rsinstruct.htmIn a nutshell you use a current to heat up the parts using their own electrical resistance. Most welders will do this if you use carbon or tungsten rods as tips, but in a pinch just copper works. Solder will not stick to chrome plating which can also be useful. There is an episode of "How its Made" TV where they make eyeglass frames using resistance soldering.
