I would check your booster and lines carefully. The incident that drove me to parking my car and begin tearing it apart, was when I burned 3 exhaust valves.
My engine started to run "off" and was down on power. I did a compression check and had 3 dead cylinders, no compression.
What had happened, was that my brake booster had developed a leak. the leak was so bad, it made that half of the intake manifold go lean, and burned 3 of the valves on that half of the intake plenum...the 4th was showing signs of burning lean/hot and was about to burn as well.
I knew about the leak, but thought "well, my brake pedal is still good, and everything feels ok, so it must not be that big of a deal so I'll just keep driving it like it is"
