Page 1 of 3 1 2 3
Wheelie Bars and Parachutes... #1340599
11/24/12 04:02 PM
11/24/12 04:02 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
My crystal ball is telling me I'll be needing both a set of wheelie bars and a chute in the very near future.. Neither of which I have any hands on experience with..
The car is a back half, tubbed Duster with a ladder bar set up.. I believe it already has the mounts for the wheelie bars.. but I need a whole lotta learnin on what ever you wanna teach me..
So if you car to share the in's and out's of what I need.. what I should buy.. and what I should look out for.. I'd appreciate it..
Re: Wheelie Bars and Parachutes... [Re: Jeepmon] #1340600
11/24/12 04:14 PM
11/24/12 04:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Longer bars have better leverage and with bars that
are 70" or longer I wouldnt run the spring type...
I have 62" with the spring at the back wheels...
Re: Wheelie Bars and Parachutes... [Re: Jeepmon] #1340601
11/24/12 05:05 PM
11/24/12 05:05 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
I have these kicking around the garage....They are 35" long.
Re: Wheelie Bars and Parachutes... [Re: Jeepmon] #1340602
11/24/12 06:09 PM
11/24/12 06:09 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I would get Stroud parachute if you ever packed a simpson you hate life when you use it. http://www.stroudsafety.com/DragChutes.html
With wheelie bars get them longer and from a good place like
http://www.jerrybickel.com/
http://www.rjracecars.com/
I got a wheelie bar kit from another company only thing I used from there's was the chrome/moly had to get the wheels and hardware from Jerry Bickel
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Wheelie Bars and Parachutes... [Re: 87MO DAK] #1340603
11/24/12 07:20 PM
11/24/12 07:20 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I have those bars and a Stroud chute...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Wheelie Bars and Parachutes... [Re: Eric] #1340604
11/24/12 08:34 PM
11/24/12 08:34 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
I will suggest a spring loaded chute over the pull the handle and hope it comes out.
If it were me I would shy away from spring loaded wheelie bars. Just me, my opinion.
You shouldn't anything longer than 60-62".
Re: Wheelie Bars and Parachutes... [Re: JD Dart] #1340605
11/24/12 09:23 PM
11/24/12 09:23 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
good advice & great parachute,and when its mounted correctly you can take it off with 1 bolt.
Re: Wheelie Bars and Parachutes... [Re: fishy340] #1340606
11/24/12 09:58 PM
11/24/12 09:58 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Are there any pros or cons regarding the Anthony jones engineering wheelie bars?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Wheelie Bars and Parachutes... [Re: HOTMOPR] #1340607
11/24/12 10:31 PM
11/24/12 10:31 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Don't know if you are fabbing it up yourself, if somebody else I would go talk to Mike Bolla, he is across from MEW and does great work. just mentioning him as I believe he is close to you.
BTW, did you make up your mind on a box? just wondering if you are gonna play in SP or be one of the fastest cars in Pro.
Re: Wheelie Bars and Parachutes... [Re: Keith Richards] #1340608
11/25/12 12:17 AM
11/25/12 12:17 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
Hmmm don't know why a Stroud is any easier to pack than a Simpson? I got the Simpson IIRC it was quite a bit cheaper? Mine has worked fine the few times I have pulled it, didn't touch the brake at all in this video till I actually came to a full stop around the corner course i was only doing 148 and Sonoma has a long shutdown and a bit uphill.
http://www.youtube.com/watch?feature=pla...p;v=S36VkZdDdkw
Re: Wheelie Bars and Parachutes... [Re: Keith Richards] #1340609
11/25/12 12:33 AM
11/25/12 12:33 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have used three RJ Racecars wheelie bar kits and they worked great. My chutes are both Simpson PITA to pack but we rarely pull them. Never did at Sonoma or Sac and that was going 170 in the big tire car.
Re: Wheelie Bars and Parachutes... [Re: Eric] #1340610
11/25/12 04:13 PM
11/25/12 04:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Eric(Twinky Butt)got your letter,thanks.
In your case it's call sissy sticks.
Re: Wheelie Bars and Parachutes... [Re: B G Racing] #1340611
11/25/12 05:02 PM
11/25/12 05:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Things Don's race car won't require. I'll take slow bracket racers for $200 alex!
Re: Wheelie Bars and Parachutes... [Re: B G Racing] #1340612
11/25/12 09:04 PM
11/25/12 09:04 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That's his new nickname???Didn't anyone warn him NOT to go BEHIND the barn??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Wheelie Bars and Parachutes... [Re: hemi-itis] #1340613
11/25/12 09:48 PM
11/25/12 09:48 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
In the spring we'll stuff the Bear in the Arrow...just have to make sure he has his depends on for that pass.
Re: Wheelie Bars and Parachutes... [Re: Eric] #1340614
11/25/12 09:50 PM
11/25/12 09:50 PM
tboomer Online work
tboomer  Online Work
Eric....I heard that Bob won't drive go-karts...
Re: Wheelie Bars and Parachutes... [Re: Keith Richards] #1340615
11/26/12 01:29 AM
11/26/12 01:29 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks for your responses guys..
Do have another question.. is the length of the bars determined by the weight of the car.. or is it the power of the motor...?
Re: Wheelie Bars and Parachutes... [Re: Keith Richards] #1340616
11/26/12 01:30 AM
11/26/12 01:30 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I looked for you at Sonoma... you werent there
Re: Wheelie Bars and Parachutes... [Re: Jeepmon] #1340617
11/26/12 02:05 AM
11/26/12 02:05 AM
Windsor ,Ca.
K
K
Windsor ,Ca.
Ok Don I will go sideways from the post topic, spent the prior week in Alabama and came home Friday with the full intention of going then mid-Saturday went for a long bike ride and here is what I came up with on that ride (read excuses!!!)
1) Why go out and race when I can get another good ride in tomorrow.
2) Besides the motor home is already winterized and right now cannot fathom the thought of towing out with the truck. (yes, it has spoiled me)
3) I know it is gonna be 11 am before the 1st car goes down the track due to the fog and that means probably one time shot,
4) New motor should be ready just before the 1st real race next year.
5) If I play hooky from racing tomorrow after my bike ride maybe the Mrs's and I can take the Harley out since I don't seem to make time for it anymore.
Day went pretty good although felt way like I should be somewere else........aaarghhh
Drank coffe rode my bike, went for another short bike ride with the wife then took the Mrs's for a ride on the loud bike then watched the last few rounds on 1320.com aaarghhhhh
Is 2013 racing season here yet?
Only bad part was Rich's text at 8am saying he would be late to the track? sorry Rich I am not there either!
OK back on subject, I think you will need those aforementioned parts and remember I am the one who told you "get ready to open up that wallet to this disease!"
keith
Re: Wheelie Bars and Parachutes... [Re: Keith Richards] #1340618
11/26/12 02:29 AM
11/26/12 02:29 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Those are some nice excuses.. I like them..
I was trying to stay polite.. but yeah.. I remember.. and yeah.. I curse you under my breath everytime I pull out the wallet.. lol
Seriously.. yeah, you were right.. its getting pretty darn expensive.. and the car isnt even race ready yet
Page 1 of 3 1 2 3
