Re: Wheelie Bars and Parachutes...
[Re: Jeepmon]
#1340600
11/24/12 04:14 PM
11/24/12 04:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Longer bars have better leverage and with bars that are 70" or longer I wouldnt run the spring type... I have 62" with the spring at the back wheels...
[Re: fishy340]
#1340606
11/24/12 09:58 PM
11/24/12 09:58 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
Are there any pros or cons regarding the Anthony jones engineering wheelie bars?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: Keith Richards]
#1340608
11/25/12 12:17 AM
11/25/12 12:17 AM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
Hmmm don't know why a Stroud is any easier to pack than a Simpson? I got the Simpson IIRC it was quite a bit cheaper? Mine has worked fine the few times I have pulled it, didn't touch the brake at all in this video till I actually came to a full stop around the corner course i was only doing 148 and Sonoma has a long shutdown and a bit uphill. http://www.youtube.com/watch?feature=pla...p;v=S36VkZdDdkw
#1340609
11/25/12 12:33 AM
11/25/12 12:33 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
We have used three RJ Racecars wheelie bar kits and they worked great. My chutes are both Simpson PITA to pack but we rarely pull them. Never did at Sonoma or Sac and that was going 170 in the big tire car.
#1340616
11/26/12 01:30 AM
11/26/12 01:30 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Don't know if you are fabbing it up yourself, if somebody else I would go talk to Mike Bolla, he is across from MEW and does great work. just mentioning him as I believe he is close to you.
BTW, did you make up your mind on a box? just wondering if you are gonna play in SP or be one of the fastest cars in Pro.
I looked for you at Sonoma... you werent there
[Re: Jeepmon]
#1340617
11/26/12 02:05 AM
11/26/12 02:05 AM
Keith Richards
Windsor ,Ca.
Ok Don I will go sideways from the post topic, spent the prior week in Alabama and came home Friday with the full intention of going then mid-Saturday went for a long bike ride and here is what I came up with on that ride (read excuses!!!) 1) Why go out and race when I can get another good ride in tomorrow. 2) Besides the motor home is already winterized and right now cannot fathom the thought of towing out with the truck. (yes, it has spoiled me) 3) I know it is gonna be 11 am before the 1st car goes down the track due to the fog and that means probably one time shot, 4) New motor should be ready just before the 1st real race next year. 5) If I play hooky from racing tomorrow after my bike ride maybe the Mrs's and I can take the Harley out since I don't seem to make time for it anymore. Day went pretty good although felt way like I should be somewere else........aaarghhh Drank coffe rode my bike, went for another short bike ride with the wife then took the Mrs's for a ride on the loud bike then watched the last few rounds on 1320.com aaarghhhhh Is 2013 racing season here yet? Only bad part was Rich's text at 8am saying he would be late to the track? sorry Rich I am not there either! OK back on subject, I think you will need those aforementioned parts and remember I am the one who told you "get ready to open up that wallet to this disease!" keith
[Re: tboomer]
#1340619
11/26/12 10:05 AM
11/26/12 10:05 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Eric....I heard that Bob won't drive go-karts...
You got that right Ted,go-karts are for little kids. It's like dating the ugly fat girl,they can be a lot of fun but you wouldn't be able to "Bear" it if some one seen you.
[Re: Jeepmon]
#1340623
11/26/12 01:50 PM
11/26/12 01:50 PM
Al_Alguire
Las Vegas
The longer the bars the more leverage they have. You planning on using them as a tuning tool or a safety device? Lots of stuff to learn if you plan to use them as a tuning device for sure. If you truly use them in this way 1/4" and inch the wrogn way can lead to very bad results. I'll show you in a bit. As for how long. HP plays a rol as well as rear suspension set up weight bias, shocks and how well they control things and so on. This is how I did it with the big tire car. We loaded the car in the trailer as far forward as I was comfortable with. Shut the rear door and measured what was left. Viola we had our bar length, in my case 74". I sure you know we use them as a tuning aide on both cars. I tend to ride the bars for a fair amount. Back to the 1/4" deal. In this video and picture my crew chief had the bars set incorrectly. 1/4" of stagger on the wrong side lead to this. This is midflight Oh yeah this was with a set of 50" bars on the car. Which do not provide near enough leverage on my car. We went to the long bars but bent the uppers three times before we finally buolt a set of double wall slip tube uppers. Like I said we tended to ride them pretty hard back then. We now have a much better pair of custom built rear shocks and can calm it down a bunch. Here is the video version http://www.youtube.com/watch?v=PhaW9zfEkZE&feature=plcp
[Re: Jeepmon]
#1340629
11/27/12 08:31 PM
11/27/12 08:31 PM
MR_P_BODY
Some wheelie bars have flat bar for the bottom, some have round tube.. does this make any difference?
Also, we've measured the clearance in the trailer and we have between 60 and 65 inches of room with the door close.. Is this an appropriate length for a Duster, A body car?
The lower bar doesnt matter... that is in tension but the upper bar is in compression... if you can get 65" in your trailer then thats what your gonna run... no way would I spend time to pull the bars off every time I wanted to load... I use to have my cabinets at the front but with the golfcart in front and the car behind I was too long... so I winched the car in backwards so the bars would go under the cart... then I moved my cabinets to the left side of the trailer and I can pull the cart to the front wall and drive the car in forwards now... I have about 6" to spare now
[Re: hemi-itis]
#1340630
11/27/12 08:43 PM
11/27/12 08:43 PM
Al_Alguire
Las Vegas
Solid round tube is what you want..Not spring loaded or flat spring types. IF you want something you can tune with. If you want the look then by all means AS for length way to many facotrs but in general the longer the better. Better leverage less shock..
[Re: hemi-itis]
#1340631
11/27/12 08:46 PM
11/27/12 08:46 PM
Al_Alguire
Las Vegas
On the chute deal if you are looking for ease of packing thats easy. Stroud wins hands down. In my case we pull it once a year so that is not a big deal.
[Re: Al_Alguire]
#1340633
11/27/12 09:00 PM
11/27/12 09:00 PM
MR_P_BODY
Al is correct and mine are round bar(I dont care for the flat ones) but if you go with a 65" I would run the springs at the wheel... they slow the impact on shorter bars otherwise it will unload the tires... I usually run the wheels about 2" off the ground in gear(in my sig pic they are 4")
[Re: Al_Alguire]
#1340634
11/27/12 11:32 PM
11/27/12 11:32 PM
Posts: 9,835 MI, usa
dvw
MI, usa
Since I really don't know much about bars, what is the problem with flat style or springs? I guess I'm just looking for something to keep it from going up to high. Don't believe I'll use them to tune,just a safety net to save the oil pan and headers. Any thoughts? Doug
[Re: dvw]
#1340635
11/28/12 03:07 AM
11/28/12 03:07 AM
Al_Alguire
Las Vegas
Doug you will likely be fine with them. They work great for that purpose, but not as a tuning aid. Difficult to control a wheelie ith a spring loaded bar.
[Re: dvw]
#1340637
11/28/12 09:23 AM
11/28/12 09:23 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
What about the single wheel bars?
Plynouth VIP '67 TT IC EFI
[Re: Jeepmon]
#1340641
11/28/12 02:26 PM
11/28/12 02:26 PM
MR_P_BODY
One thing I do like about the spring type(in pic) is that IF you want to lock the spring you can(make it solid) with a few washers EDIT also with the nut near the wheel you can tighten the spring to make it beefier(pressure) and get less movement
[Re: B G Racing]
#1340643
11/28/12 02:34 PM
11/28/12 02:34 PM
Al_Alguire
Las Vegas
Don you want a solid bar..
[Re: hemi-itis]
#1340646
11/28/12 03:44 PM
11/28/12 03:44 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
I am still curious about the packing of the chute.I had planned on all Simpson products.It looks to me that ALL the chutes are a PITA. Also is thier a science on the length of the bars? Or is it fit what fits
Look at the instructions for packing the two different chutes and you will see the difference, Simpson takes longer. But if you like Simpson get one I have one and just take it out and put it back in a few times and you will get it, like Al said you wont use it that much anyway
[Re: Al_Alguire]
#1340650
11/29/12 02:58 PM
11/29/12 02:58 PM
Posts: 3,746 Riverside, California
Lil Demon
But Demon dont need em He just likes to look cool
Oh really? You didn't think you needed them either until that fateful day at Infineon. I like the piece of mind and the hope that one day my car will run like it's supposed to.
[Re: Jeepmon]
#1340656
11/30/12 12:51 PM
11/30/12 12:51 PM
Lil Demon
Hey Bill.. when is that bad beast gonna see the track again?
No clue. There are some things on it that I want to get addressed before it rolls into a staging lane again. That's time and money and you know my situation - which hasn't improved any.
