Re: Looks to me like these pistons are upside down [Re: LSP] #1339913
11/23/12 03:10 PM
11/23/12 03:10 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My B1 pistons have the exhaust valve reliefs 080 deeper than the intakes.I run a 113 lobe seperation, 113 installed CL and use 1.7 rocker ratio. Just shy of .800 lift.
What cam are you running spec wise?
Re: Looks to me like these pistons are upside down [Re: Bob_Coomer] #1339914
11/23/12 04:35 PM
11/23/12 04:35 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
They look good to me. It's great that the exhaust valve relief is deeper. You should have lots of clearance for a nasty big cam
Re: Looks to me like these pistons are upside down [Re: 66er] #1339915
11/23/12 08:35 PM
11/23/12 08:35 PM
Rock Springs
Bob_Coomer Offline OP
Rock Springs
Cam is a older Ultradyne Roller, i purchased from dewayne porter awhile back.... has a .450 something lobe and I have a 1.75 rocker arms..... I forget the exact specs, but works out to be right at .800 gross lift.. Duration is 276@50 and is a 108 LSA IIRC.
I have had some brain farts with this one.. I know the rods are correctly installed etc. This crank has a large chamfer (LA Enterprise billet) with Bill Miller aluminum rods...
