Looks to me like these pistons are upside down
#1339893
11/23/12 12:47 AM
11/23/12 12:47 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Sure looks like it... I checked them out and the rods are numbered to each cylinder, and are turned right on the crank side, and by looking at the valve reliefs the intake relief is the larger one. The pistons sure look like they are upside down to me.. But turning them over and installing them the rods would be wrong as far as the tangs (always to the pan rail side. and the bevel facing to the outside of the journal... I told him to wait and see what was said. These are B1 Originals pistons, and this is my engine, a friend is assembling. Pretty sure they are upside down. ![](http://i93.photobucket.com/albums/l45/The_Dakota_Kid/086.jpg)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Looks to me like these pistons are upside down
[Re: Cab_Burge]
#1339904
11/23/12 01:25 AM
11/23/12 01:25 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
number 7 doesn't look to good, but the rest are fine.
Joe
Without Data, you’re just another guy with an opinion.
[Re: Bob_Coomer]
#1339906
11/23/12 01:28 AM
11/23/12 01:28 AM
Yeah, number 7 is way too far down in the hole...
[Re: MR_P_BODY]
#1339909
11/23/12 02:58 AM
11/23/12 02:58 AM
Bob_Coomer
Rock Springs
Guess Im just paranoid... Why is the exh valve relief a good .040-.060 deeper? IDK The rods were oriented correctly. and I know the larger relief is always the intake... and the pattern is E-II-EE-II-E so.... If you look close you can see the hard-blok etc...
[Re: Bob_Coomer]
#1339910
11/23/12 03:30 AM
11/23/12 03:30 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
The exhaust always needs more clearance because the piston chases the exhaust valve closed.
