Re: Project angry bird...68 roadrunner
[Re: pnypwr]
#1339819
02/17/13 12:17 AM
02/17/13 12:17 AM
Posts: 4,872 connecticut
pnypwr
connecticut
the rear crossmember will need some patches but its basically flat steel and its well hidden where it needs a patch (behind the reinforcement bracket) so im confident I can patch this and noone will be the wiser. the goodmark panel is the wrong gauge and the holes are just holes not like the original, the amd panel is a 69 part with the oval gas tube hole so ill make mine work,
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#1339821
02/17/13 12:20 AM
02/17/13 12:20 AM
pnypwr
connecticut
on the upside i need to knock the springs off the axle and ill have a large amount of space again...the rear rails which are cherry and the trunk floor ate up some real estate in the shop...thats tomorrows project...well see what gets done then
[Re: pnypwr]
#1339822
03/02/13 10:49 PM
03/02/13 10:49 PM
pnypwr
connecticut
back at it today...got the rest of the parts car dissassembled and its parts harvested...I saved the complete rear end as im prob going to need it as the one under the car is junk im sure...was told it was a grip...its not big surprise! but it does have an adjustable snubber...oh its welded to the pumpkin
[Re: pnypwr]
#1339823
03/02/13 10:51 PM
03/02/13 10:51 PM
pnypwr
connecticut
got the rear seat shelf all cut out and rustoleum in the rails...luckily the rear rails are solid, they were filled with mud built bees nests alot of that
[Re: pnypwr]
#1339824
03/02/13 10:52 PM
03/02/13 10:52 PM
pnypwr
connecticut
got the fuel tank crossmember in the trunk
[Re: pnypwr]
#1339825
03/02/13 10:53 PM
03/02/13 10:53 PM
pnypwr
connecticut
the rear seatshelf is in and has its two bolts holding it down, just needs to be welded but not feeling that today
[Re: pnypwr]
#1339826
03/02/13 10:57 PM
03/02/13 10:57 PM
pnypwr
connecticut
still on the fence on what to do with the inner wheelhouses, i have some good used ones but seperating the inner and outer doesnt look like much fun...atch whats there which isnt much...and its punky behind the trunk hinge support...or get new amd!
Tomorrow hopefully ill feel like welding and get the shelf all i and button up the front floors, then cut out the tail light panel and rear x member, get the trunk floor at least in and then im takin a break from this thing for a while...days are getting longer and i need to turn my attention to something i can actually drive this spring
[Re: basketcase]
#1339828
03/03/13 10:31 PM
03/03/13 10:31 PM
Posts: 1,896 New England
Q5_Ed
New England
I am quite impressed with your effort in saving that car. Wish you were closer by, I would have had a good side job for you.
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
[Re: pnypwr]
#1339830
03/03/13 11:36 PM
03/03/13 11:36 PM
pnypwr
connecticut
got as much welding in the rear shelfdone as I could take today...its 2/3 done its not to comfortable in there welding...
[Re: pnypwr]
#1339831
03/03/13 11:37 PM
03/03/13 11:37 PM
pnypwr
connecticut
then I Went to the rear tail light panel...something felt good about taking the sawzall to the back end...I wanted to cut the whole thing up but thought better of it! got the tail panel out and rear crossmember out...clamped the new one to keep the rails from moving around.
[Re: pnypwr]
#1339832
03/03/13 11:41 PM
03/03/13 11:41 PM
pnypwr
connecticut
other end...it fits like its meant to be there...oh yeah its original steel it is meant to be there.
[Re: pnypwr]
#1339833
03/03/13 11:42 PM
03/03/13 11:42 PM
pnypwr
connecticut
cleaned up the trunk floor and painted it with the weld thru coating...this is prob hands down the nicest orig trunkfloor ive ever seen...just some pitting and a couple (2) very small holes...
[Re: pnypwr]
#1339834
03/03/13 11:44 PM
03/03/13 11:44 PM
pnypwr
connecticut
the trunk gutter tried to protest the sawzalling of the tail panel...but it quit holding on and dropped
[Re: pnypwr]
#1339835
03/03/13 11:45 PM
03/03/13 11:45 PM
pnypwr
connecticut
I had to test fit the trunk floor before going inside for the night...its nice to see this thing with solid floors again...progress...
[Re: pnypwr]
#1339836
03/03/13 11:47 PM
03/03/13 11:47 PM
pnypwr
connecticut
tomorrow if i feel like it after work...ill weld up the rear x member, trim the inner wheelhouses of whats left of the orig trunk floor and fit it and start welding...prob just get it in place and finish up inside of the car...
[Re: flypaper]
#1339838
03/04/13 08:28 AM
03/04/13 08:28 AM
pnypwr
connecticut
looks can be deceiving frank...those were useable...so were the front door posts roof structure and rear frame rails...outer rockers will need some attention....got to get my plan down for the rear...do I do the dutchman first and then the quarters oruse the orig dutchman and tack on the quarters then replace it? however it may fall off once the quarters come off...oh and the package tray is useable and its not even cut for giant speakers!
