Re: Project angry bird...68 roadrunner
[Re: pnypwr]
#1339799
01/06/13 11:22 PM
01/06/13 11:22 PM
Posts: 4,872 connecticut
pnypwr
connecticut
in the hole...getting it into position was kind of a challenge, the rear transition panel to the trunk was in the way...it needs to be cut out anyway, but I didnt want to start cutting before welding in the floor...but we made do
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#1339801
01/06/13 11:25 PM
01/06/13 11:25 PM
pnypwr
connecticut
got the left side all welded in,that was all my knees, back and attitude could take for one day...
[Re: pnypwr]
#1339802
01/06/13 11:26 PM
01/06/13 11:26 PM
pnypwr
connecticut
pass side is next...I cant wait...
[Re: pnypwr]
#1339806
02/03/13 05:18 PM
02/03/13 05:18 PM
pnypwr
connecticut
Back at it today ripping out what's left of the trunk floor
[Re: pnypwr]
#1339807
02/03/13 10:54 PM
02/03/13 10:54 PM
pnypwr
connecticut
guess we need some inner wheelhouse also as it dissolved...
[Re: pnypwr]
#1339808
02/03/13 10:55 PM
02/03/13 10:55 PM
pnypwr
connecticut
at least the rails are solid
[Re: pnypwr]
#1339809
02/03/13 10:56 PM
02/03/13 10:56 PM
pnypwr
connecticut
however once I started cleaning up the trunk floor I found some pinholes, so I Might as well replace it with new, and then might as well do the x member new and assoc parts...or maybe throw in the towel, and find a better car
[Re: pnypwr]
#1339810
02/04/13 12:24 AM
02/04/13 12:24 AM
I had thought the same thing with my project at the beginning so I changed direction of the build. I truly feel for ya.
[Re: ]
#1339811
02/10/13 12:33 AM
02/10/13 12:33 AM
pnypwr
connecticut
just gets frustrating when its a total pile...was supposed to have a sure grip too...it doesnt, good thing I have the correct 742 case grip in stock. but on the other hand I could put the 8 3/4 under my convertible and drop the dana in the runner...hmmm then a 4 speed...maybe I should just get it solid first
[Re: pnypwr]
#1339812
02/10/13 12:58 AM
02/10/13 12:58 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
is the rest of the x member solid? as in, could you get by with a small patch? seems like your almost over the hill on welding?
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopars_1]
#1339813
02/10/13 01:34 AM
02/10/13 01:34 AM
pnypwr
connecticut
yeah it has one small hole next to the reinforcement, ill see what I have when I get it off, im going to drill off the trunk floor and see how bad it is, if its a couple small fixes I guess I Can live with it
[Re: basketcase]
#1339816
02/17/13 12:12 AM
02/17/13 12:12 AM
pnypwr
connecticut
cleaned up the trunk floor I had, just to see how bad it was and if I should drop 4 bills on getting an amd floor, oddly enough the 2 holes that opened up when i first started to clean it up are the worst of it, another small hole opened so I guess I can deal with 3 tiny patches
[Re: pnypwr]
#1339817
02/17/13 12:13 AM
02/17/13 12:13 AM
pnypwr
connecticut
the holes shouldnt be to hard ro fix...there is some pitting but once its sealed and painted and a trunk mat it will be all good.
