Page 3 of 6 1 2 3 4 5 6
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339779
12/24/12 08:33 PM
12/24/12 08:33 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
other side went too
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339780
12/24/12 08:36 PM
12/24/12 08:36 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
I used the 4 door cowl as it was already separated, so I could paint inside it...figured it wouldn't hurt to lay some paint in there...I blasted the cap and the hats on the lower so no surface rust or scale
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339781
12/24/12 08:37 PM
12/24/12 08:37 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
lower was rock solid no pinholes or anything
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339782
12/24/12 08:39 PM
12/24/12 08:39 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
clamped up ready to weld
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339783
12/24/12 08:40 PM
12/24/12 08:40 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
oops wrong pic...welded up and the welds all ground down, ready for some high zinc primer...according to the guy at napa said this is the best stuff for an area like this...primed
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339784
12/24/12 08:43 PM
12/24/12 08:43 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
I used 3m weld thru 2 on the seams then taped them, shot the primer and then I got a rattle can of a color close to the orig UU1 they couldnt interchange my paint code at napa, and their tech line was closed today...so I found a chip that was pretty darn close...its under the cowl anyway
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339785
12/24/12 08:44 PM
12/24/12 08:44 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
nice to see some new color on this thing...makes you feel like ya actually made some progress...painted the bottom of the cap also...
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339786
12/24/12 08:46 PM
12/24/12 08:46 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
I did the top hats in rustoleum also just an added measure noone will ever see...got the cap on and clamped down
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339787
12/24/12 08:48 PM
12/24/12 08:48 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
all welded up...need to dress the welds, but ive had enough for one day...there is alot of welds holding that thing on... up next is the floors...after i finish the welds in the engine comp and cowl...nice not to have that gaping hole anymore
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339788
12/28/12 11:24 AM
12/28/12 11:24 AM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
1981 Dodge D150 360 auto
Re: Project angry bird...68 roadrunner [Re: basketcase] #1339789
01/05/13 11:51 PM
01/05/13 11:51 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
onto the floors...the first chunk removed
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339790
01/05/13 11:52 PM
01/05/13 11:52 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
the front pinchwelds drilled out
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339791
01/05/13 11:53 PM
01/05/13 11:53 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
whats left of the rear foot wells removed...the floors were toasted
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339792
01/05/13 11:57 PM
01/05/13 11:57 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
I was told it has solid floors... not so much...the carnage, oh the humanity
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339793
01/05/13 11:58 PM
01/05/13 11:58 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
however christmas came late...after the floorpan time to spin this jewel around and start on the back end!
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339794
01/06/13 03:03 PM
01/06/13 03:03 PM
MI
chapdog105 Offline
chapdog105  Offline
MI
Looks like an awesome project! AMD is the way to go! I bought a lot of their metal for my convertible project. I'm not a body man, but the that installed the panels says they're the best.
Re: Project angry bird...68 roadrunner [Re: chapdog105] #1339795
01/06/13 11:14 PM
01/06/13 11:14 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
I wish AMD was around when I put my vert together...i scrounged the world for parts for that car...ended up drillin apart a real clean 4 door 68 satellite, that car gave alot to my vert, but stuff just wasnt around and if it was it was very expensive for junk. I saw a pair of 69 plym vert quarters that needed the bottom and he wanted 1250 for the pair then you had to skin them. I made due with what I had and the 4 door may have given up its trunk channels, and in front of the boot well may have come off a hardtop...did what I had to do yano?
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339796
01/06/13 11:16 PM
01/06/13 11:16 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
now back to the regularly scheduled rot box...floor mounting area cleaned prepped, and I painted inside the t bar x member and frame rails...look like i missed a spot tho oh well, not like it will ever see rain snow or daily use ever again
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339797
01/06/13 11:17 PM
01/06/13 11:17 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
the donor floor panel ready to rock
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project angry bird...68 roadrunner [Re: pnypwr] #1339798
01/06/13 11:19 PM
01/06/13 11:19 PM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
it was a tight fit going in, a second person would have been super helpful...
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
