30 x 9 slick #1339255
11/21/12 11:57 PM
11/21/12 11:57 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Who's are you using? I was looking at a Hoosier bias ply
A body around 3000lbs with around 450 hp and similar ft/lbs. Ladder bar suspension
Alan Jones
Re: 30 x 9 slick [Re: LA360] #1339256
11/22/12 12:05 AM
11/22/12 12:05 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
If an automatic use the Hoosier radial. It is worth around a tenth over bias ply.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 30 x 9 slick [Re: sixpackbee] #1339257
11/22/12 12:15 AM
11/22/12 12:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are 30 x 9 Hoosier radial slicks. They work good for me and handle good since I have a radial tire in the front. Ron
Re: 30 x 9 slick [Re: 383man] #1339258
11/22/12 01:30 AM
11/22/12 01:30 AM
LA360 Offline OP
LA360  Offline OP
I thought about running the radial slick, but the track I would be racing on can be a little marginal as far as preparation.
Alan Jones
Re: 30 x 9 slick [Re: LA360] #1339259
11/22/12 01:50 AM
11/22/12 01:50 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I dont like that tall of slick for the A body. I tried it one time and the car felt squirrly on the top end.
MT makes a nice 28x9 ET drag slick that works great IMO for a ride like yours. Whats Your rear gear ratio though?? Thats important too.
Re: 30 x 9 slick [Re: Sport440] #1339260
11/22/12 02:01 AM
11/22/12 02:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You know I was not even thinking about it being an A-body. I know on my boys Dart the 28" tires would hit the front of the 1/4 going thru the traps also. The 26 or 27 fit ok in the stock wheelwell. Dont know if your wheelwells are modified or not. I like the 30 on my B-body because of the bigger wheelwell but I gotta agree it may be to much in the A-body. Ron
Re: 30 x 9 slick [Re: 383man] #1339261
11/22/12 04:49 AM
11/22/12 04:49 AM
LA360 Offline OP
LA360  Offline OP
My rear wheel arch opennings are modified to accept the taller tire.
My current gear ratio is 5.37:1 which is probably a little high for what I am going to be doing. The next engine to go in will be a high RPM engine, which is what the gears were originally bought for. This engine was a fill in/back up engine, we had our first child and I wasn't sure when I would get to finishing the R5 engine off.
Alan Jones
Re: 30 x 9 slick [Re: LA360] #1339262
11/22/12 10:18 AM
11/22/12 10:18 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
When I bought my car, it had 30x9 Hoosier radial slicks. It was very consistent and had no problems hooking. When I realized they were wore out at a race at Norwalk, I went to Harlow Tire onsite and unfortunately they didn't have the 30x9 in stock so I went with a 29x9 Hoosier bias slick. My car slowed a tenth, but it was just as consistent.
The radials are definitely quicker.
Re: 30 x 9 slick [Re: LA360] #1339263
11/22/12 03:10 PM
11/22/12 03:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow thats alot of gear. I dont blame you for wanting at least a 30" tall tire with that gear. I do like the way mine hook and handle and I even drive on the street with them. Good luck , Ron
Re: 30 x 9 slick [Re: 383man] #1339264
11/22/12 07:36 PM
11/22/12 07:36 PM
PA
Belvedere500ci Offline
PA
30x9 hoosier radial! They hook to the cords. People were telling me how great they were so I took the plunge and bought a set. I ll never go back to bias again! I'd take off any 10.5 11w, 12 and run the 30x9s. They also have 30x10.5 radial but from what I hear they work on some cars and not on others.
1967 Plymouth Belvedere II 383
1968 Plymouth Barracuda 383
2005 Ram 3500 5.9Diesel
1979 Dodge Power Wagon 360
Re: 30 x 9 slick [Re: LA360] #1339265
11/22/12 08:29 PM
11/22/12 08:29 PM
Locomotion Offline
Locomotion  Offline
That's what I always point out when the subject of radials comes up. I can't recall the last time I had a problem at an IHRA divisional/national event. I love my Hoosier lightweight radials also!
Earlier this year, as in years past, I was VERY inconsistent at Orlando Speed World (Florida) and rarely went. In the last 6 weeks I attended 2 Stock/Super Stock combo events put on by our regional association at Orlando. I was leading the points and wanted to insure I stayed there despite my traction concerns. They had gotten a new track prep crew since the last race I attended and I was happily surprised to see traction as good as it's ever been there or anywhere else! The last race, with great air, resulted in the best ET's and 60' times ever with my usual "tune". All 60's were witin .01. It just depends on how much time, effort and material the track wants to put into it and if they know what they are doing.
Whatever 9" you go with, get as close to a 10" rim as you can. If you don't want to cut-up/mini-tub the car, you should be able to go with a wider tire and rim if you get a 3/4" offset kit for the leaf springs. Nevermind, I see you have lader bars!
Traction may still be a concern when you go to the stronger engine. Michael Beard tried running his Volare with a Stocker-type Cal-Trac suspension when he put a mild, SS-legal Drag Pack FI 360 engine in for SS/GT. He was running mid-high 10's, but the motor made too much power to hook as consistently as was necessary. So he back-halved the car.
Re: 30 x 9 slick [Re: Locomotion] #1339266
11/23/12 12:34 PM
11/23/12 12:34 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Guys here is 2 tons of fun on 9" goodyears with stiff side wall. 1.50 60ft. times.
Re: 30 x 9 slick [Re: mopartony] #1339267
11/23/12 06:42 PM
11/23/12 06:42 PM
regina sask
N
nitrousr Offline
nitrousr  Offline
N
regina sask
Another vote for the hoosier 30X9, we run them on our duster and love them. Always hook and the handling compared to bias is night and day especially if you are into the occasional street drive. Just noticed the car has goodyears in the sig lol old picture.
