6.1 engine stand bolts #1339071
11/21/12 04:00 PM
11/21/12 04:00 PM
Jax.Jags Offline OP
Jax.Jags  Offline OP
Hi, I need to purchase some bolts to mount a 6.1 on my engine stand. I believe they are metric (8mm) and I am guessing they need to be at least 120mm in length. I also know the strength rating is different for metric bolts and I don't know what the equivalent is for grade 8. Can anyone enlighten me on this? And, any sources for buying these? Lowe's/Home Depot come up empty. Thanks for the help.
Re: 6.1 engine stand bolts [Re: Jax.Jags] #1339072
11/21/12 07:16 PM
11/21/12 07:16 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
3/8 x 16 bolts,you'll need to measure your setup to ensure the correct bolt length. I use the Ace next to my house as they carry every useful thing that the big guys don't.
Re: 6.1 engine stand bolts [Re: Jax.Jags] #1339073
11/25/12 03:05 AM
11/25/12 03:05 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Grade 8 is equivalent to grade 8.8 metric. I also think there is a metric grade 10.xx something but probably overkill
