Re: Cobra Jet hits wall ..
[Re: grncpe]
#1338244
11/19/12 08:32 PM
11/19/12 08:32 PM
Triple Threat
Renton Washington
He pretty clearly keeps the hammer down and grabs another gear when its spinning and basically on top of the center line. Decent pedal job in the air, driving after landing leaves something to be desired.
[Re: Lil Demon]
#1338246
11/19/12 09:43 PM
11/19/12 09:43 PM
He was trying to turn in the air which was his big mistake. I dont know what he was thinkin' Keep steering wheel straight in the air and all would have been " A OK".
#1338247
11/19/12 09:55 PM
11/19/12 09:55 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
And you know this why?
Oh that's right you're Gandhi
[Re: Cab_Burge]
#1338249
11/19/12 10:26 PM
11/19/12 10:26 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
This is not complicated. It appears from the outside view he has the wheels cut right when in the air and leaves it that way when it hits the ground. Guess what the tires hit the ground it turns.
Then watch the in car. Yep right on turns the wheel right in the air and never straightens up before hitting the ground.
It's a mistake none the less that is what happened.
Sorry to see anyone have a wreck.
[Re: Cab_Burge]
#1338250
11/19/12 10:28 PM
11/19/12 10:28 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
the thing I notice is the RPMs went over 8k, so if it would have been a gen 3 hemi it would have smoaked some rod bearings
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1338252
11/19/12 10:38 PM
11/19/12 10:38 PM
Posts: 2,449 nc
earthmover
nc
Ok i know how that ghuo. Lol
[Re: sixpackgut]
#1338254
11/19/12 11:42 PM
11/19/12 11:42 PM
Posts: 341 Highland beach Fl
poisondart2
Highland beach Fl
[Re: bigdad]
#1338258
11/21/12 01:10 PM
11/21/12 01:10 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
When you put an in-experienced driver in a car over his head that's often the result. Compound that with a spool and he has even less chance, because the spool ends up steering the car, often straight into the wall (sometimes several times). As expensive as they are, Detroit Lockers or locking diffs go a long way in being able to save a crossed up car, because you can actually steer the car once the diff unlocks. I've broke several axles (at the spline) and never even got out of the groove, running Detroit Lockers - try that with a spool. Not trying to start a big whizzing match, just putting out a little info to consider when buying parts.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: gregsdart]
#1338259
11/21/12 01:17 PM
11/21/12 01:17 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
I don't know the circumstances that caused the problems with this run, but Steve is an experienced driver, having raced Super Gas and Super Comp for several years, and his current Mustang is one of the quickest and fastest cars in Comp Eliminater (twin Turbo), I believe I saw him run 6.40's at 220 at Indy 2 years ago. He is also the president of Aeromotive fuel systems and has been involved with drag racing for many years.
Be a Rebel- Break the Laws of Physics!
