Small block Valve to piston clearance?
#1338061
11/19/12 07:03 PM
11/19/12 07:03 PM
Posts: 237 Redding,CA USA
440charger500
Redding,CA USA
Finishing up the 340 and got the cam degreed in @ 106 and heres the P-V clearances .085 exhaust & .092 intake with 0 lash, cam calls for .014-.016 lash. To do any more we are going to have to buy some cam keys or a timing chain with more adjustment. What do you guys think?
Engine details 340 eddy heads Lunati 60442 solid cam .586 ex .566 in @ .050 251-259
Re: Small block Valve to piston clearance?
[Re: 440charger500]
#1338062
11/19/12 07:05 PM
11/19/12 07:05 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Thats a little tight on exhaust, street or strip motor?
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 440charger500]
#1338064
11/19/12 08:31 PM
11/19/12 08:31 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Solid or hydraulic? Roller or flat tappet? RPM range? Spring pressures?
I've run less with a solid flat tappet with 440 PSI over the nose with no issues. You could move the cam around a little to gain some more exhaust clearance, you can run less on the intake but that doesn't look bad to me.
