Oil viscosity choice for strip and street
#1337998
11/19/12 06:11 PM
11/19/12 06:11 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
what oil viscosity is your choice and why i currently run Royal Purple HPR 20/50 in my 440.i do run a HV pump and deep sump.It runs at 35-40psi hot idle,70-75psi running. i am thinking of dropping to RP 10/40.my engine-dyno shop has recommended trying this as they have seen HP gains on their race car motor,nissan 240Z. weather here never sees much below maybe 7 degrees C in winter to just over 40 degree C in summer. thoughts ? things to watch out for ? or simply try it out on the dyno ? Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Oil viscosity choice for strip and street
[Re: BradH]
#1338000
11/19/12 08:27 PM
11/19/12 08:27 PM
tex013
Sydney,Australia
thanks Brad, what i was thinking plus i like Reher's first rule - maybe stick to the 20/50
Tex
[Re: tex013]
#1338001
11/19/12 10:52 PM
11/19/12 10:52 PM
Posts: 7,506 Az
Crizila
Az
I run RP XPR 10W40 at the track. With the pressures you are presently running ( a little high IMO ) 10W40 will be a good step. I also run a flat tappet cam with no problems.
Fastest 300
[Re: BradH]
#1338002
11/19/12 10:59 PM
11/19/12 10:59 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
IMO, for a flat-tappet cam, nothing thinner than the 10w40 you're proposing changing to.
So would 5W-30 RP be ok for a roller cammed engine?
[Re: topside]
#1338005
11/20/12 02:31 AM
11/20/12 02:31 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
I like to keep the clearances on the tight side and use thin oil. Have used regular (Mobil) 5w40 synthetic for years in all engines I've built, including flat tappet.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#1338006
11/20/12 06:42 AM
11/20/12 06:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I use 20/W50 Valvoline racing oil. Ron
[Re: Crizila]
#1338009
11/20/12 12:23 PM
11/20/12 12:23 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Mobil One 15w50 synthetic for me. Bearings look great at freshen ups so I'm sold on it.
[Re: BradH]
#1338011
11/20/12 12:57 PM
11/20/12 12:57 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Like was mentioned above, the "correct" oil viscosity is a factor of oil clearance, oil temps, application (short-duration vs. endurance), etc. Spending some time on the Joe Gibbs oil web site looking through their oil application guidelines may help improve understanding of this.
I also have some concerns about using oils that IMO are too thin for extended street use, especially when it comes to flat-tappet cams. I look at things like the HTHS (High Temp High Shear) ratings for different oils because that is a good indication of how the oil should handle heavy-interface loads such as cam & lifters.
You'll have trouble finding any Xw30 oil w/ a HTHS rating much higher than 3.5, whereas you can get as high as a 5.x HTHS rating w/ heavier oils. In that respect, oil viscosity can be (like so many other things) a compromise.
Damn Brad, you`ve got too much time on your hands. Some people love to over-complicate things and oil along w/all of the other subjects beaten to death is another one of them. I have to question how many actually try stuff instead of asking others who may not know what works and what doesn`t. I keep doing things that "experts" say can`t/shouldn`t be done again like the 8" vert on the street, spool thin oil etc. My clearances are bigger than most and even w/a high volume pump and only 6-quarts of oil, I still see 20-25 hot at idle and 65+ above 7000 rpm`s and never a problem EVEN street driving as in LOTS of desert miles and even dirt roads occationally.............just do it!
[Re: Thumperdart]
#1338012
11/20/12 01:09 PM
11/20/12 01:09 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I run 6qts of 5W30 and one quart of Lucas oil stabilizer. It gives me the lower oil pressure I needed and the lucas oil additive keeps things nice and slimey or so it seems. Its a solid roller with about 2500 street miles on it now and 50-60 passes.
68 Barracuda Formula S 340
[Re: Thumperdart]
#1338013
11/20/12 01:11 PM
11/20/12 01:11 PM
BradH
... Some people love to over-complicate things...
Guilty as charged!
FWIW (serious note), if you're still running Mobil 1 10w30 as I recall from the past, I really don't believe what they sell now is a "beefy" enough oil for the power level you're making. I know you're all about bang for the buck and not over-spending (I try to be, but often fail miserably at it), but that stuff is about one step above horse p!ss now from all the info I can find on it.
I've stopped running it in my '02 WRX, if that's any indication of my loss in confidence w/ Mobil 1's street oils.
[Re: Thumperdart]
#1338015
11/20/12 02:00 PM
11/20/12 02:00 PM
jyrki
Finalnd, Perkele
We have run 5W40 mobil 1, but only make 1580+ hp..., same oil in our 970 hp + nitrous B1 and after one season it was spotless. Didn't even bother to open the other one since we checked it in 2010. It propably isn't the oil with all the best properties, but it's good enough for us and you can buy it here anywhere.
