HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal #133778
10/08/08 10:47 AM
10/08/08 10:47 AM
Amherst
P
plumcrzyTA Offline OP
P
Amherst
First, I am trying to make a man garage and I was working in there last night and I dropped a 12 foot ladder on her 71 Demon.It kills me because the paint on it (was) PERFECT!It was not as bad as I thought or told her.It just put a chip in the paint on the front fender.I think that was all.(couldn't look at it to long)It could have been alot worse.Then,I have the original 340 block on a stand and I took off the plastic cover and noticed there was some surface rust on one of the cylinder walls.(was not a good night)I did not even look at all of them.One was enough to get me mad at myself.I did oil them.Should I have greased them? What is the best way to remove the rust and to keep it from coming back.:(
I am now thinking of putting a bed in the garage,just in case.
THANKS,David
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: plumcrzyTA] #133779
10/08/08 11:11 AM
10/08/08 11:11 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
give it light hone then clean and sray with cozmolene in spray can its that brownish liquid wax seals off all air contact with bores. is this dave milican and shedevil?
MOPAR OR NO CAR
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: plumcrzyTA] #133780
10/08/08 11:11 AM
10/08/08 11:11 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
If it is just surface rust you can run a cylinder hone and clean it up.
How you treat the block depends largely on how long it is going to sit there. Generally a good coating of WD40 and wrapping in plastic will keep things from rusting for the short term. There is always Cosmoline (spelling)for longer term storage.
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder [Re: 68CoronetRT] #133781
10/08/08 11:17 AM
10/08/08 11:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The plastic is the problem , the stuff I had under plastic surface rusted , even stuff I sprayed WD on , the stuff left out in the open did not
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: hemigod426] #133782
10/08/08 11:17 AM
10/08/08 11:17 AM
Amherst
P
P
Amherst
Yes, it is.GOOD MEMORY!!!
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: plumcrzyTA] #133783
10/08/08 11:18 AM
10/08/08 11:18 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If the rust isn't to bad hit it w/a hone. I did this on my engine and it had some pretty bad surface rust. Ran fine all year when I could keep the trans together.
Is it going to be a while before you get it put together and running? Grease or something like ARP assembly lube might be better than oil for long storage.
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder [Re: JohnRR] #133784
10/08/08 11:37 AM
10/08/08 11:37 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Plastic only keeps the dust out. Traps moisture in. Watch the Glad commercials LOL. If its kept inside, your better of covering with cloth so it can breath. You could also get some of those desiccant(sp?) packs. You know like come packed in electronics and cameras and such to absorb moisture. Not sure where you get them MailBoxesToGo?? but here's a link http://www.google.com/products?hl=en&...=4&ct=title Couple large packs laid in the lifter valley should work I would suspect.
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder [Re: Scott Carl] #133785
10/08/08 11:41 AM
10/08/08 11:41 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Any boat place will have them.
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder [Re: plumcrzyTA] #133786
10/08/08 03:14 PM
10/08/08 03:14 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
THANKS,David
Sorry to hear about the Demon.. but as far as the 340 goes.. I agree with what is said about using plastic, but if it were me I would not worry about it. I had a 440 block that was left out (under hood) without a head on it. All four cylinder had water and all four had bad rust. So bad I used sand paper to scuff it back down. Then I put the head on it and fired it up. Maybe I got lucky, maybe not, but that 440 is one of the strongest ones I have seen and its still running. I suppose you will hear all the stories, but if you have just some small rust I wouldn't even bother with a hone.. my
RS23L7 4-Speed
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder [Re: Mopar_Mike] #133787
10/08/08 03:19 PM
10/08/08 03:19 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Amsoil has a Heavy duty metal protector that leaves a wax type coating. Check out the (AHM) MPHD Heavy duty metal protector.
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: plumcrzyTA] #133788
10/08/08 07:18 PM
10/08/08 07:18 PM
If you continue to damage her car your bed may end up in the garage whether you want it there or not.
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: RapidRobert] #133789
10/08/08 07:43 PM
10/08/08 07:43 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
If it's a motor than is going to get hot tanked anyway, you can always just paint the bores with a rattle can. A guy I know used to do this - never had a problem.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: 5wndwcpe] #133790
10/08/08 08:23 PM
10/08/08 08:23 PM
qc
mxbeep Offline
mxbeep  Offline
qc
light scuff with a scotch pad should be enough.
I always spray inside my unused blocks with vehicle anti rust oil spray.
Can be bought at auto parts store for same price as any oil spray
Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal [Re: plumcrzyTA] #133791
10/08/08 08:56 PM
10/08/08 08:56 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
Clean it up, find a distributor for CRC chemicals, and tell them you want a can of SP-400. This is basically spray cosmoline, and works well. WD-40, CRC-336, or brake cleaner cuts it right back off. Hope this helps.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
