Re: HELP! WIFE NOT HAPPY! Some surface rust on cylinder wal
[Re: plumcrzyTA]
#133783
10/08/08 11:18 AM
10/08/08 11:18 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If the rust isn't to bad hit it w/a hone. I did this on my engine and it had some pretty bad surface rust. Ran fine all year when I could keep the trans together.
Is it going to be a while before you get it put together and running? Grease or something like ARP assembly lube might be better than oil for long storage.
[Re: JohnRR]
#133784
10/08/08 11:37 AM
10/08/08 11:37 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
The plastic is the problem , the stuff I had under plastic surface rusted , even stuff I sprayed WD on , the stuff left out in the open did not
Plastic only keeps the dust out. Traps moisture in. Watch the Glad commercials LOL. If its kept inside, your better of covering with cloth so it can breath. You could also get some of those desiccant(sp?) packs. You know like come packed in electronics and cameras and such to absorb moisture. Not sure where you get them MailBoxesToGo?? but here's a link http://www.google.com/products?hl=en&...=4&ct=title Couple large packs laid in the lifter valley should work I would suspect.
[Re: plumcrzyTA]
#133786
10/08/08 03:14 PM
10/08/08 03:14 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
First, I am trying to make a man garage and I was working in there last night and I dropped a 12 foot ladder on her 71 Demon.It kills me because the paint on it (was) PERFECT!It was not as bad as I thought or told her.It just put a chip in the paint on the front fender.I think that was all.(couldn't look at it to long)It could have been alot worse.Then,I have the original 340 block on a stand and I took off the plastic cover and noticed there was some surface rust on one of the cylinder walls.(was not a good night)I did not even look at all of them.One was enough to get me mad at myself.I did oil them.Should I have greased them? What is the best way to remove the rust and to keep it from coming back.:( I am now thinking of putting a bed in the garage,just in case. THANKS,David
Sorry to hear about the Demon.. but as far as the 340 goes.. I agree with what is said about using plastic, but if it were me I would not worry about it. I had a 440 block that was left out (under hood) without a head on it. All four cylinder had water and all four had bad rust. So bad I used sand paper to scuff it back down. Then I put the head on it and fired it up. Maybe I got lucky, maybe not, but that 440 is one of the strongest ones I have seen and its still running. I suppose you will hear all the stories, but if you have just some small rust I wouldn't even bother with a hone.. my
RS23L7 4-Speed
[Re: plumcrzyTA]
#133788
10/08/08 07:18 PM
10/08/08 07:18 PM
RapidRobert
If you continue to damage her car your bed may end up in the garage whether you want it there or not.
[Re: RapidRobert]
#133789
10/08/08 07:43 PM
10/08/08 07:43 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
If it's a motor than is going to get hot tanked anyway, you can always just paint the bores with a rattle can. A guy I know used to do this - never had a problem.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
