All I did from yesterday was pull the distributor and check it pick up resistance was 550 MSD says 500 to 700 is good.
turning over it gave .31 to .28 volts. MSD say that does not matter?? so the reluctor is real rusty and some on the pick up too.
So I took the distributor apart and cleaned the rust off as best I could on the reluctor got the faces real clean with emery cloth.
Test again and pick up resistance is 570 and the cranking over volts are .34 to .28 much the same.
Put the distributor in and set close it fires right up I hold it at 1800 it stays there rock solid till I get it up to 180.
Let off it idles at 1500 in neutral and 1000 in gear. thought it would have been higher as I thought I turned idle screws up quite a bit to get 1400/1500 missing yesterday and it would not stay idling in gear.
anyways I check the timing and it is at 21 so I turn it up to 39 and now idle is at 1800 + so I turn it down put emerge on block front tires and set it to idle 1100 to 1200 in gear still way cool. shuts off and just touch the key and it fires back up.
Video is just touching the key on both start ups.
I did put Dialectic Grease on dizzy connector to 6AL.
http://www.youtube.com/watch?v=JlzYhzFO7L8&feature=youtu.be
