C-body Scarebird brakes #1337493
11/18/12 10:43 PM
11/18/12 10:43 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I see alot of positive comments about the Scarebird brake conversions when I searched around the web.There were a few negatives about spacers and having to trim the brackets but I am OK with that. So other than the minor fitment issues are there any other issues that would keep me away from installing them on a friends 67 300
Gus
64 Plymouth Savoy
Dana 60
Re: C-body Scarebird brakes [Re: fourgearsavoy] #1337494
11/18/12 11:21 PM
11/18/12 11:21 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I cannot speak from firsthand experience on Scarebird, but it is appealing from what I've read. However, why not just go with a 1970-up C body disc set up? Proven set up and parts are reasonable. This is what I did on my 67 Newport.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: C-body Scarebird brakes [Re: EWJ] #1337495
11/18/12 11:33 PM
11/18/12 11:33 PM
Royersford, PA
bschargerse Offline
bschargerse  Offline
Royersford, PA
I almost went the Scarebird route on my '66 until I scored a factory set from a '73 for free. Keep your eyes peeled, they do pop up occassionally. Recently there was a listing on ebay for a SSBC C-body kit for cheap.
Brian - 1971 Dodge Challenger
"The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
Re: C-body Scarebird brakes [Re: EWJ] #1337496
11/19/12 12:22 AM
11/19/12 12:22 AM
Rittman Ohio
Rittman Ohio
Well if it were my car thats what I would do,but the older gentleman I'm doing this for has limited funds and he cant pay me to go out and scrounge for the parts,clean and blast everything,source all the new parts,then assemble it all and make it work for under $500
I collected all the parts for the conversion on my Savoy for about $350 doing all the work myself.I really don't have the time to do the leg work and this Scarebird deal sounds like the best option for this particular job.
Thanks.
Gus
64 Plymouth Savoy
Dana 60
Re: C-body Scarebird brakes [Re: fourgearsavoy] #1337497
11/19/12 12:27 AM
11/19/12 12:27 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
OK, understood. Please then give us your honest feedback on the Scarebird set up. Thanks.
Ed
Re: C-body Scarebird brakes [Re: EWJ] #1337498
11/19/12 01:39 AM
11/19/12 01:39 AM
my own world
theraif Offline
theraif  Offline
my own world
i have though about this for our dart because i got all new ball joints and stuff and its all nice and alined all ready lol
Re: C-body Scarebird brakes [Re: fourgearsavoy] #1337499
11/19/12 02:01 AM
11/19/12 02:01 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Thanks.
Gus
I installed a Scarebird Kit on a 65 Fury for a customer and it worked extremely well, easy installation and nice performance. Same situation, customer was on a budget and wanted a nice set of disc brakes in the $500.00 range, I think he had around $425 in them including new Rotors, MC and calipers. They use Chevy Calipers on most of their kits, easy and cheap to buy.
Re: C-body Scarebird brakes [Re: 65pacecar] #1337500
11/19/12 04:27 AM
11/19/12 04:27 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I've seen this kit at Carlisle Gus.
http://ecihotrodbrakes.com/dodge_plymouth_discbrake_conversions.html
Compare the caliper brackets. The Scarebird bracket appears to be welded together. http://www.scarebird.com/index.php?id=33
I think when the dust settles that the ECI kit will be within a few dollars of the Scarebird and IMHO a better and certainly more complete kit.
It is my understanding that they are now making unicast rotors for the 69-72 spindles which are easier to find than the 73's.
I think Dr Diff sells sleeves that will adapt the larger 73 bearings to the <73 spindles if the cheaper unicast rotors are fiction. The front pump seal for a 700R4 works for a grease seal.
If you put out a call here somebody might have a set of C-body spindles that they would part with for reasonable $$ and you will still be in the same $ ballpark.
Kevin
Re: C-body Scarebird brakes [Re: Twostick] #1337501
11/19/12 05:05 AM
11/19/12 05:05 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Kevin
I used an ECI kit on my R/T when I had it. Everything fit pretty nice, but the only drawback for me was the billet dust caps wouldn't clear a centerless(Magnum 500) wheel. It stuck out too far. If I could have found a flat steel cap off a newer car that would fit and stay put in the billet hub, they would have been great.
They use Camaro/Firebird calipers, pads, and brake hoses. Rotors, too, I think.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: C-body Scarebird brakes [Re: fourgearsavoy] #1337502
11/19/12 12:59 PM
11/19/12 12:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Check www.cbodydrydock.com for feedback. There are a few guys over there who have messed with the kits.
- Stu Harmon
Re: C-body Scarebird brakes [Re: feets] #1337503
11/19/12 03:14 PM
11/19/12 03:14 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
I did a set up on my 68 Chrysler 300
Not sure of the brand ? Don't remember now
It used a GM caliper which worked good BUT was under size for the size car.
Full size mopars are big and heavy and need a big piston in the front caliper, same as a 150 truck.
So what ever kit, make sure the calipers are large
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: C-body Scarebird brakes [Re: moparts] #1337504
11/19/12 03:28 PM
11/19/12 03:28 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That is the one advantage to the ECI kit. The GM caliper it uses apparently has a bigger piston than Mopar does so for a given pedal pressure you should get more clamping force with the GM caliper.
Kevin
Re: C-body Scarebird brakes [Re: Twostick] #1337505
11/19/12 08:35 PM
11/19/12 08:35 PM
PA
68_CONV_300 Offline
68_CONV_300  Offline
PA
I had one of the original scarebird kits on my 68 300 ... there were issues with bearings and the spindles and eventually they got it figured out and had to buy some spacers (for $30 in addition to the original kit I bought). If I had to do it again I would def go with the ECI kit with the new machined aluminum hubs and correct bearings without paper thin machined spacers.
Re: C-body Scarebird brakes [Re: 68_CONV_300] #1337506
11/20/12 12:45 AM
11/20/12 12:45 AM
Rittman Ohio
Rittman Ohio
The kit I was looking at used Dodge Ram calipers and 72 LTD rotors which makes for a nice large caliper and big rotor as well
I think I will give it a try and give a complete report on the entire conversion.
Gus
64 Plymouth Savoy
Dana 60
Re: C-body Scarebird brakes [Re: fourgearsavoy] #1337507
11/21/12 11:12 PM
11/21/12 11:12 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Gus
looking forward to seeing this conversion
Re: C-body Scarebird brakes [Re: 72d100] #1337508
12/18/12 03:48 PM
12/18/12 03:48 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
any updates?
Re: C-body Scarebird brakes [Re: fourgearsavoy] #1337509
12/18/12 05:14 PM
12/18/12 05:14 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Gus
Glad to see someone posted ECI, I would give them the nod over Scarebird due to 're-engineering' that Scarebird had to do after brakes were out on the street. And I'll never be a supporter of sleeves for wheel bearings, that's just an ugly way to meet a goal.
I know we get excited about any disc brake kit, but weren't Fords kinda known for poor brakes back in the day? I know that LTD rotor has less mass than a C-body rotor, and that translates into less robustness to handle heat. Is it insufficient? Only way to tell is to try them...
Interesting to hear about the 700R4 seal. When I was lookign for cheaper 69-72 C-rotor options (which use the same bearign and seals as the drum spindles), the seal was one item I couldn't find a suitable substitute. Might hafta re-open those research notes.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: C-body Scarebird brakes [Re: Fury Fan] #1337510
12/18/12 09:21 PM
12/18/12 09:21 PM
Rittman Ohio
Rittman Ohio
Gus
We will be leaning to the ECI kit until I can talk to Doctordiff about his kits.I really like the looks of the ECI deal but I may have to trim the studs down to fit the owners lug nuts he just bought with his rally wheels.
I will show pics of this conversion when I do it
Gus
64 Plymouth Savoy
Dana 60
