Re: 1967 -1969 barracuda grill
[Re: Posest]
#1336934
11/18/12 08:47 AM
11/18/12 08:47 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
Nothing from the front of a '69 will fit on a '67, everything is different (although they look similar at a quick glance). 1967 and '68 headlight bezels are the same I think, but as you know, the plastic grill inserts are different. The turn signals in the grill are also different between '67 and '68.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Posest]
#1336937
11/18/12 03:43 PM
11/18/12 03:43 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
I am sure this has been asked a dozen or more times but here I go asking again. I purchased a 1967 barracuda last spring. I have several header panels and grills but all are fairly rough. My question is, aside from the honeycomb center of the 67, what else is different. I have found a place to purchase a complete set for 68 & 69 but nothing for a 1967. Will the surrounds and fender extensions fit mine? My front clip is out for bodywork and I would like to have an idea of what to do for a grill set when it comes home. Also I was wondering if the window belts have all parts included or do I need to salvage what I can from mine. Thanks
Are you specifically looking at brand new headlight and grille setups from PG Classics, www.beaparts.com , Herb's Parts, etc??
You could use your old 67 inserts by changing the one verticale support brace with a repro 68 insert. The 67 aluminum grille inserts with honeycomb/grid inside are usually in pretty nice shape. Not terribly hard to restore either.
[Re: Posest]
#1336939
11/18/12 09:41 PM
11/18/12 09:41 PM
autoxcuda
So Cal
Yes I was looking at a set from the BEA catalog.
I don't see them at all on the online catalog. Only the plastic 68 inner grilles. But...
Drill out the rivets of the vertical 68 supports on your new nosecone surrounds and replace with a painted-straight-nice-restored-used 67 support.
Then restore your 67 inner aluminum grilles and bolt on.
Then use the 68 repro headlight buckets. I extremely doubt they will ever make them with the other bolt holes comfigurations.
[Re: Posest]
#1336941
11/19/12 05:24 AM
11/19/12 05:24 AM
autoxcuda
So Cal
Thanks, I think I will order the complete 68 srill and put the 67 inserts into it then. I was unsure until I had others ideas on what would work.
Can you get them without the plastic 68 grille insert and 68 chrome grille surround??
Basically without these: (of course w/o broken grille)
