Re: If you were to build a bb stroker engine????????????? [Re: Streetwize] #1336773
11/19/12 09:41 PM
11/19/12 09:41 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
for those of you running the 470 strokers, what combos or kits did you use? 440source, muscle motors, hughes? what hp/torque numbers are you hitting?
Re: If you were to build a bb stroker engine????????????? [Re: dangina] #1336774
11/20/12 12:16 PM
11/20/12 12:16 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Go 540! They make great power and mine is going on its 3rd year. Plus it's 70 cubic inches bigger then what these guys recommend.
Re: If you were to build a bb stroker engine????????????? [Re: FastmOp] #1336775
11/23/12 04:32 PM
11/23/12 04:32 PM
PA
Belvedere500ci Offline
PA
Hey your the Super Series guy! Lol. Won it in 09? Dave, I built a 500ci >400 using all 440 source parts. Parts were great. Company was easy to deal with. Very happy with the build. I put the engine in my 67 Belvedere on Caltracs, 30x9 radials and I wasn't impressed. Way to much low end. The car was a monster if it hooked. But the 2nd you had to run behind street or at a marginal track it would blow a tenth off in 60ft. Tube chassis or 4 link it's the perfect engine. I'd try a 451 or 470 if you want stroke. Flat tappet cam and a good set of heads. Top end and mph win races not cubic inch. I found out the hard way. But I still have the engine and it should make the 68 4 link Cuda I'm building an easy 9sec ride
1967 Plymouth Belvedere II 383
1968 Plymouth Barracuda 383
2005 Ram 3500 5.9Diesel
1979 Dodge Power Wagon 360
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336776
11/23/12 04:55 PM
11/23/12 04:55 PM
Real North Cal.
66er Offline
66er  Offline
Real North Cal.
I love my 470. I've have 7 year (about 1000 passes) on it and it still runs very hard and consistent. I replaced the rod bearing last year, but the original ones still looks great. I think the size of your engine should mach the size of your heads. standard port will support up to 470ci Max wedge will support 500ci+ with reasonable compression, stall speed, gear, ect...
Re: If you were to build a bb stroker engine????????????? [Re: Belvedere500ci] #1336777
11/23/12 05:08 PM
11/23/12 05:08 PM
AndyF Online content
AndyF  Online Content
You should be able to fix that issue with gearing. A 500 incher will pull pretty good with higher gears.
Re: If you were to build a bb stroker engine????????????? [Re: AndyF] #1336778
11/23/12 05:43 PM
11/23/12 05:43 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
Re: If you were to build a bb stroker engine????????????? [Re: ro23car] #1336779
11/23/12 07:27 PM
11/23/12 07:27 PM
It was an answer to a question. He asked how to build a BB stroker engine. I wrote an entire book on the subject. Why post an answer when he can read the book? The book covers it in more detail and has pictures. A post will just be a short answer that leaves out a lot of details.
Re: If you were to build a bb stroker engine????????????? [Re: 65racer] #1336780
11/24/12 12:28 AM
11/24/12 12:28 AM
ill
dennismopar73 Offline
ill
This is not a street driver, this is for my
race car, I am just looking into another avenue
in case the block I have at the shop is not going to
cut it.
I am not looking to rotate the world or anything
like that, just want something that will be consistent,
and require very little maintenance, as in trouble
free, something to race every weekend, not something
I am going to have to live with in the shop all the time.
I have the book, and have read it through several times,
but am still undecided, but I am leaning toward the 470"
combo, I have gone as quick as 6.80's with the 383 engine
in the car, with a flat tappet cam, steel heads, nothing
really special, but this was with machine work by a guy
who really knew what he was doing, but he passed away a couple
of years ago, and since then I have had to go else where
for machine work, and not everyone knows the real tricks
of engine machining, I learnt a long time ago that there
is a big difference between someone who knows what needs to be done to
make an engine fast, and someone who knows just how to do
machine work, the same combination is in the car as when he was
doing my machine work, but it's not the same work, the car has been
consistently slow, by about 2 tenths, and I can't get it to run
any faster, so I am leaning toward building something with
a little more horsepower, so maybe it will pick it back up
et wise, that's what I am really after,
So thanks for the replies, gonna have to decide what I am gonna do
pretty soon, but that depends on what my wallet will stand, I race on a budget, always have and always will, for 40+ years, and the car has to pay for itself, I guess I am lucky in that respect, as I have
always been able to keep my ego in check, and not let it get the best of me, and have always and I mean always have been able to show a little profit at seasons end, since I have been racing, not braging
about it or nothing like that, I just watch my bottom line real close.
this is what I was going to ask as I to am in the same position thank you
Re: If you were to build a bb stroker engine????????????? [Re: AndyF] #1336781
11/24/12 01:06 PM
11/24/12 01:06 PM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Good post I'am going to get moving on my project soon. Need to make up my mind 500 or 470?
Re: If you were to build a bb stroker engine????????????? [Re: dare_dude] #1336782
11/24/12 02:02 PM
11/24/12 02:02 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
After much research I went with a low deck 470 and am very happy with the combo. I believe there is more if I want to turn up the r's, but this is for bracket racing. Car has been a best of 5.82 in the hills of southern ky with a 1.23 60 ft. Car weighs 2510.
