Turn signal problem #133668
10/07/08 10:10 PM
10/07/08 10:10 PM
East central Missouri
larryj Offline OP
larryj  Offline OP
Car is 65 Dodge Coronet if it makes any difference. My right signal stopped working yesterday. Dash indicator comes on but doesn't blink. Sounds like burned out bulb, right? No such luck. Tail light comes but dosn't blink, front light comes on, on both sides but doesn't blink. Both front lights are dim while they are on. Any ideas? I thought maybe bad ground, but I don't see where they ground. Any help greatly appreciated.
Re: Turn signal problem [Re: larryj] #133669
10/07/08 10:13 PM
10/07/08 10:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Try cleaning out the bulb socket first- maybe the bulb isn't grounding all that well inside the socket.
Re: Turn signal problem [Re: In_The_Pink] #133670
10/07/08 10:18 PM
10/07/08 10:18 PM
check front/rear right side bulbs/sockets/grounds.
