650-700hp Mopar 440cid motor build
#1336468
11/17/12 12:10 PM
11/17/12 12:10 PM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Hey guys
Need you opinion about parts ( heads,camshaft etc. ) what to use for streetable pump gas ( max. CR around 10-10.5 ) `72 year 440cid motor. Parts what we have allready is Edelbrock Performer intake and 750cfm Speed Demon mechanical carburator What camshaft you suggest to use and do Edelbrock RPM heads are fine for that kind of power cause I really dont think OEM heads are capable for our plans
Thanks Georg
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: 650-700hp Mopar 440cid motor build
[Re: Georg]
#1336472
11/17/12 02:26 PM
11/17/12 02:26 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I believe that 650 hp is achievable with a pump gas 440, but like others have stated, not with the parts you have. Fully ported RPM would possibly work IMO, but I have not done it myself. I believe that others have found that they can support that power level with full on RPMs in other applications.
[Re: BSB67]
#1336473
11/17/12 02:46 PM
11/17/12 02:46 PM
Posts: 20,657 in a cattle trailer down by th...
Guitar Jones
A 300 shot of n2o should put you there.
[Re: Georg]
#1336475
11/17/12 03:46 PM
11/17/12 03:46 PM
Posts: 43,277 Bend,OR USA
Cab_Burge
George, my first pump gas stroker motor made 612 HP at 5600 RPM and 644 Ft. lbs at 4500 RPM, it was a 400 block bored to 4.375, I bought a Ohio 4.25 stroke crank for it and used a set of CAT brand 6.800 long H beam forged steel rods and s set of custom Ross 22 CC dished pistons that made a measured 9.25 to 1 compressio ratio. I use a set of big valve ported 906 heads that didn't flow very well and a Eddy low deck six pak intake and stock type vacume carbs. The cam is a custom grind Comp Cams solid roller that is 260 degrees at .050 I switched heads later to a set of Eddy RPM that I had MCH CNC port and that picked the car up .3 ET and 4 MPH in the 1/4 mile, that was proablly worth 40 to 60 HP You can make a big motor make big power easier than you can with a smaller C.I. motor BTW, you'll need a bigger carb also, big motors, high HP motors, need lots of air to make that power
[Re: Brian Hafliger]
#1336478
11/17/12 06:16 PM
11/17/12 06:16 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Yep, my thoughts too. In fact, you could probably do it with a 275 flat tappet.
[Re: Dunnuck Racing]
#1336480
11/18/12 05:38 AM
11/18/12 05:38 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
To make that much power, the RPM heads need so much work that there is no sence in going that route. You have basically two choices; build an engine with the parts you have and it will make x-horsepower, or shoot for the 650-700 hp range and make the parts choices accordingly. Here is what I would propbly do to keep the budget reasonable. If willing to retain the stock crank I would pick Mahle pistons and rigns for it and bore the block for them. Rods, from 440 source or equivalent. Enlargen the oil galleys of the block and use a 1/2" pickup, main studs and linehone the block. I might also do a short fill for the block, which should be done before machining. Last thing would be trial assembly, measurement and cut the decks to achieve zero deck height. For heads I would choose Pro Comp aluminum heads and port them. I might use other rockers depending of the budget, Harlan sharp or even the Indy rockers may be better than what pro comp offers. Indy rockers have greater offset and the heads require some grinding to fit them. For the intake I would use Edelbrock Victor with a 2" dominator adapter and a 1050 dominator carb. You should end up with around 11:1 CR which should work fine with 98E gas you have, no problem there. I would use an old tried and true cam motion roller available from Indy, 276/283 at .050" and .69"/.63" lift. Then get the lifters etc where you can get a good deal and last order the pushrods after you know the lengths required. 2" headers, a good ignition and I'm pretty sure you should be in the range you desired, or if eveything goes like in the movies, perhaps even a little beyond.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#1336481
11/18/12 03:45 PM
11/18/12 03:45 PM
Georg
Europa, Estonia
Thanks a lot guys! Lot to think about now...
Premium Performance
[Re: Georg]
#1336482
11/18/12 08:32 PM
11/18/12 08:32 PM
Posts: 554 Kentucky
clovis
Kentucky
I make in that range with a stock crank 451/400 using Stage VI heads (300 flow), a mopar 590 cam, Indy 440-3 intake and a quick fuel 1050 dominator, however I am at 13:1. It seems like you have to trade cubic inches for compression.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
