aluminum 426 hemi cold valve lash #1335960
11/16/12 12:57 AM
11/16/12 12:57 AM
Stuttgart, Arkansas
rickseeman Offline OP
Stuttgart, Arkansas
On a cast iron hemi with aluminum heads I set the valve lash at -7 to be correct when it is hot. What do I set it at cold with a Keith Black aluminum block and aluminum heads? Thanks for youir help.
2011 Drag Pak Challenger
Re: aluminum 426 hemi cold valve lash [Re: rickseeman] #1335961
11/16/12 03:35 AM
11/16/12 03:35 AM
I used the suggestions from Crane to start out with -.012 and check it again when the motor got up to operating temps., that worked well That was with a KB street Hemi aluminum block and aluminum Dart water heads.Start with -.12 and see how it works for you and let us know
Re: aluminum 426 hemi cold valve lash [Re: Cab_Burge] #1335962
11/16/12 04:48 AM
11/16/12 04:48 AM
Australia
Teamx Offline
Teamx  Offline
Australia
I have -.016 on World Hemi and Stage V heads.
Re: aluminum 426 hemi cold valve lash [Re: rickseeman] #1335963
11/16/12 07:09 AM
11/16/12 07:09 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
0.006
8.30's @3400 lbs
Re: aluminum 426 hemi cold valve lash [Re: rickseeman] #1335964
11/16/12 10:03 AM
11/16/12 10:03 AM
an8sec70cuda Offline
I set mine .013" tighter when cold. I lash em at .010" cold so I have .023" hot. KB block, MP heads.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: aluminum 426 hemi cold valve lash [Re: an8sec70cuda] #1335965
11/16/12 11:22 AM
11/16/12 11:22 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Expansion rate on a all aluminium engine is .015/.018.This can be subtracted from the recommended hot lash setting,but never go tighter than .005. Example:If the hot lash is .026int..028 exh.Then set int.at .011 and the exh.at.013.Then check lash hot.By doing this you can determine the actual expansion rate and zero in on the correct cold setting.
Re: aluminum 426 hemi cold valve lash [Re: B G Racing] #1335966
11/16/12 11:54 AM
11/16/12 11:54 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
Thank you all. I appreciate your help.
Re: aluminum 426 hemi cold valve lash [Re: B G Racing] #1335967
11/16/12 12:56 PM
11/16/12 12:56 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I agree, but it also might matter where you live and how cold it might get when starting. For example, I have customers that have to start their aluminum engines in the winter when it's 30 degrees in their shop. With a World block and Stage-V heads I set the cold lash at .005 (when very cold) just so the valves will actually close. After warm up I typically see about .020 and .024.
Re: aluminum 426 hemi cold valve lash [Re: Mopar_Rich] #1335968
11/16/12 01:33 PM
11/16/12 01:33 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
No tighter than .005,I don't recommend anyone trying to start a race engine at below 30 degrees.I suggest some type of engine coolant heater or other means of bringing up the temperture.It's tough to control any race fuel or oil stability at that cold of temperture.
