69 Charger electrical problems #1335849
11/15/12 07:33 PM
11/15/12 07:33 PM
ontario
70plumrt Offline OP
70plumrt  Offline OP
ontario
Hi guys, I'm having problems with some wiring issues!
Started with the indicator light on dash not working.
Bulbs and fuses are fine. I noticed the horn relay clicking from time to time, no horns now, and the p/s parking light doesn't stay on.
The dash lights are all working, but not the gauges!!
After trying to fix the dash bulb I now have no indicators!!
Headlights and taillights work.
Grrrrrr. Any help appreciated!
1969 Charger 1968 Charger R/T 1972 RR TB3 340/4 spd 2002 Ram 1998 Durango
Re: 69 Charger electrical problems [Re: 70plumrt] #1335850
11/15/12 07:37 PM
11/15/12 07:37 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
I am guessing that you have an issue up in the steering column, probably the signal switch broken.
Re: 69 Charger electrical problems [Re: mopar_man] #1335851
11/15/12 09:01 PM
11/15/12 09:01 PM
ontario
70plumrt Offline OP
70plumrt  Offline OP
ontario
It was a column auto car which someone converted to floor shift and left original column.
The two wires on the indicator switch are barely hanging on!
Thanks I'll go wiggle them now
Car came with an after market wheel so I put an original on.
