Re: COMP. CAMS PRO MAGNUM ROLLER ROCKERS 1.5
[Re: ahy]
#133587
10/07/08 08:44 PM
10/07/08 08:44 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I used them on a 496B with great results (243@.050 fast lift cam with .55" lift).
Geometry was good and I like the durability of steel. The engine was apart after about 500 miles and shafts and rockers looked great. They should be matched up with Comp's shafts of correct hardness.
With really high lifts and spring pressures, galling of the shafts has been reported. The fix is to get bronze bushings installed (RAS - Rocker Arm Services is one company that does this).
In my application they worked great as supplied by Comp.
A friens had those on his 440 and they started galling of the shaft/rocker. His machinest suggested honing the rockers for a bit more oil clearance or bushing them.
[Re: 451Mopar]
#133588
10/08/08 12:04 AM
10/08/08 12:04 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Pro-Comp Electronics makes a set that is just like these, but come with bronze bushings, cupped adjuster studs for ball end pushrods that also have oiling galleys machined into them to oil over the top of the arm. Not made by Comp Cams, not made in the USA, but fairly nice stuff. Pro Comp is one off-shore company that is making a name for themselves (have you seen their heads?!)
[Re: cudarex]
#133593
10/08/08 01:55 PM
10/08/08 01:55 PM
BradH
This is the one I'm running with bronze bushings...
That's the way to do it... having RAS do their bushing mod was a really good idea.
[Re: BradH]
#133594
10/09/08 02:15 AM
10/09/08 02:15 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
These have been on my 383 for 3+yrs... Not a problem... Street driven and not EASY miles... Freeway, burnouts, hard miles! You get what you pay for... Comp Mags
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: FOXY312]
#133596
10/15/08 08:24 AM
10/15/08 08:24 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
WELL I GUESS I WONT GET THESE NOW THEY ARE TELLING ME 12/12/08 TILL SHIP OUT THAT 4 TIMES THEY BEEN BACK ORDER SIN AUG.
Seriously? Have you had an order in since August?
[Re: FOXY312]
#133598
10/15/08 01:30 PM
10/15/08 01:30 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Haven't had any issues with mine running about 500 lbs open spring pressure.
I think many posted instances of galling/metal transfer can be traced to too much spring pressure (I wouldn't run any more than 500 max), overtorqued rocker shafts (better hold downs and studs do not allow more torque, use 25 ft lbs max regardless of the hardware) and wrong assembly lube (use only regular motor oil, or one of the thin assembly lubes like clevite bearing guard....do not use anything thick and pasty).
Rich H.
Esse Quam Videri
[Re: orangecrush]
#133600
10/15/08 04:19 PM
10/15/08 04:19 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
I am running about 512lbs. spring pressure and I also had a problem with slight galling of the shafts. After cleaning up the shafts I called RAS and they said to take a dremel or cutoff wheel and cut a couple of 1/4"-3/8" long shallow grooves from the center of the oiling hole on the shaft so that oil will distribute more quickly and evenly across the shaft where the rocker rests on. I did this and it worked great. No more galling.
Like this, called banana grooving:
[Re: GTXKen]
#133601
10/15/08 07:31 PM
10/15/08 07:31 PM
Posts: 44 pa
FOXY312
pa
YES THE END OF AUG. THEY SAID THAT THEY DONT HAVE ANY SHAFTS FOR THE ROCKERS
[Re: FOXY312]
#133602
10/16/08 09:44 AM
10/16/08 09:44 AM
cudarex
Odessa, Tx.
You could do like I did and order the rockers from a Comp dealer (Dwayne Porter in my case) and buy the shafts, holdowns and studs from RAS.
[Re: ZIPPY]
#133604
10/16/08 05:41 PM
10/16/08 05:41 PM
i think i might have a couple sets of those on the shelf if you guys need them. i'll take a look tomorrow when i go back to the shop.
